Chris Lovell's Avatar
Driver door post rattle/buzz
I have an irratating little buzzing rattle in the driver door post. My 12 year old has climbed around in the back and thinks the buzz comes from the seat belt retraction unit in the door post. I'm not convinced.
Have any of you had this problem? It is just enough of a sound to be inrrating.
Thanks in advance.
CWL
'88 Carrera Cab
Old 04-13-2003, 07:12 PM
I have a rattle in my door that is caused by the window reg. If I put the window down a C-hair the rattle goes away. Does your rattle change with window position?
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 04-13-2003, 07:22 PM
Don't I wish. I have the same door rattle as you which I solve the same way. No, this rattle is a "buzz" from back there. I think I'll try to disassemble to door post and check out the seat belt return unit. It sounds like it is there or nearby there.
Any other ideas?
CWL
'88 Carrera Cab
Old 04-14-2003, 06:52 PM
