-   -   Single tire chirp with downshift (http://forums.pelicanparts.com/porsche-911-technical-forum/1063449-single-tire-chirp-downshift.html)
Christien 06-09-2020 09:40 AM
Just got back from a test drive, VR looks fine - steady at 14v on the highway, down to 13.7 with headlights, 13.5 with headlights and AC. No spikes at all, on the highway or city streets. No smell at all. Couldn't get the tire to lock up on downshifts, either going straight or in a curve. Haven't had a chance to jack it up and get under it yet.
aston@ultrasw.c 06-09-2020 11:33 AM
Porsches never act up on the test drive!
pmax 06-09-2020 11:47 AM
Any roadkill marks on the tire :D ?
Christien 06-09-2020 11:57 AM
TBH, I'm wondering if it wasn't something like that that just got stuck somewhere, burned up, and is now gone.
911pcars 06-09-2020 06:06 PM
Originally Posted by RSTarga (Post 10896870)
If double clutching eliminates the problem, could be sticking clutch.
Yes. If minimized when double-clutching, the clutch disk, if oil-fouled, will tend to grab instead of typically slip when torque continues from engine to gearbox.
If so, check rear main and/or input shaft seals.
Sherwood
DanielDudley 06-10-2020 02:05 AM
Originally Posted by anglophone1 (Post 10896978)
Clutch release bearing - mine made same noise- thought it was the belt.
A good thought. If it is the throw out bearing, it will become more obvious as time goes by.
Christien 06-10-2020 10:13 AM
Ok, I'll keep an eye (and ear) on that.
stownsen914 06-10-2020 02:29 PM
See if you can (re) create the sound other ways to isolate the cause. Or just wait to see if it appears in other scenarios, or changes with time.
For example, if it is the throwout bearing, it ought to make the sound any time you depress the clutch and not just on downshifting. Try downshifting earlier or later than usual to see if the sound changes, or perhaps it may reveal that the timing of the sound with downshifting was coincidental, etc.
