<insert witty title here>
Christien's Avatar
Single tire chirp with downshift
Out for a drive today and noticed my rear passenger side tire started chirping with downshifts. And not "sporty" downshifts, just regular driving, maybe slowing down for a turn in the road. If I double clutch it doesn't happen.
I also noticed a rather strong smell, something I couldn't place. (Not burning oil, tranny fluid, burnt clutch or tire rubber). If I had to describe it, I'd say scrambled eggs, but less sulphur-y. When I got home the engine bay looked totally normal, no leaks anywhere. 20 minutes later, the floor underneath is perfectly dry.
What could this be? The only thing that came to mind is the limited slip - I've only had this car about 4 years, and it's my first experience with LSD.
Old 06-07-2020, 08:58 AM
Still here
pmax's Avatar
Are you sure it isn't your fan belt ?
Sulphur smell could be an overcooked battery. Faulty VR will do that.
Old 06-07-2020, 10:09 AM
Christien's Avatar
fan belt is still there, and there was no light on the dash.
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 06-07-2020, 10:33 AM
Still here
pmax's Avatar
How loose is it ?
Don't rely on the lights. Use a voltmeter.
Old 06-07-2020, 10:40 AM
Thrust bearing?
Old 06-07-2020, 11:13 AM
Christien's Avatar
Belt tension feels good, about 1/2" deflection. Voltage looks good too, 13.1 with the engine off, 13.75 at idle, 13.9 at 2000rpm (without headlights, a/c or anything), measuring at the battery terminals.
Old 06-07-2020, 11:15 AM
Formerly known as Syzygy
Canada Kev's Avatar
You might have better results measuring the voltage as you're driving, not stationary. When I had a bad VR, volts were good engine off, at idle and 2000-2500 rpm. I only saw it get into the danger zone after I started driving the car - half way down the block it jumped to 16V. I just measured it at the cigarette lighter with a pigtail I made from a 12 volt accessory cord and my meter.
I believe that when the regulator goes bad it'll be high voltage, not low.
Kevin
Old 06-07-2020, 07:50 PM
Christien's Avatar
I've got a cigarette voltage meter coming today from Amazon. But none of that would explain the tire chirp on the downshift would it? I'm worried there's something going on in the differential, and maybe the smell was related to that.
Old 06-08-2020, 03:24 AM
If you're going straight, the differential part isn't doing anything. So if you're thinking the diff is essentially momentarily stopping the right rear tire, it doesn't make much sense mechanically. If a diff fully locks, it keeps both rears turning at the same rate, it doesn't stop one side.
Just out of curiosity, have you checked your CV joint bolts? Or, have you jacked the car up and wiggled the tire? Have you turned the RH rear by hand to make sure you don't have a sticking caliper or e-brake mechanism?
Matt - 84 Carrera
Old 06-08-2020, 04:07 AM
Maybe it's pulled head studs.
Old 06-08-2020, 04:20 AM
Christien's Avatar
I haven't done any of that, but I will. I know one of the calipers does stick from time to time, and I have the parts to rebuild it (it's on my list for this summer), but would that actually grip the brake disc enough to actually lock the tire up momentarily, and only during a downshift?
Though now that you mention it, I wonder if it was only happening in turns. I'm going to take it for a spin today and test that.
Old 06-08-2020, 05:03 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
If its dragging the extra drag could overcome the tires grip.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 06-08-2020, 09:11 AM
Christien's Avatar
Even at 60 kmh?
Old 06-08-2020, 09:13 AM
Diss Member
Quicksilver's Avatar
Even at 60 kmh?
The emergency brake is assisted by rotation so that could be it but you should see a bunch of heat coming off of it.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 06-08-2020, 09:52 AM
Christien's Avatar
Doesn't the e-brake only lock the driver's side wheel?
Old 06-08-2020, 09:56 AM
porsher
aston@ultrasw.c's Avatar
Both sides.
A bit of a weird one.
Some thoughts:
Can you get it to chirp by coming off the power and then going back on without shifting?
The grip of the tire is so great I can not imagine that the sound is really coming from the contact patch.
I'd look at drive shafts, suspension mounting points, engine mounting points etc
Use an IR thermometer to compare temps side to side to see if anything is dragging.
For it to smell, something is getting hot.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 06-08-2020, 10:39 AM
Christien's Avatar
I don't think it was doing that, but I can't say with 100% certainty.
I'll look at those, for sure.
Old 06-08-2020, 11:17 AM
If double clutching eliminates the problem, could be sticking clutch.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 06-08-2020, 11:25 AM
Christien's Avatar
Wouldn't that affect both wheels, not just one?
Old 06-08-2020, 11:30 AM
Clutch release bearing - mine made same noise- thought it was the belt.
Last edited by DanielDudley; 06-10-2020 at 01:04 AM.. Reason: Not edited, wrong button.
Old 06-08-2020, 12:37 PM
