IAN IAN is offline
Will cleaning out Injectors in early 911 make a difference?
I'm almost finished with a fairly major tune up..
I'm wondering if having somebody professionally clean out all of my injectors will make a difference.
Anyone have any thoughts on this??
Thanks!
Old 04-13-2003, 09:11 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
is it MFI injectors or CIS injectors?
Either way makes a difference depending on how dirty they are.
I think the procedures might be different for the 2 injectors
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 04-13-2003, 09:24 PM
I replaced mine on my 82SC, they are cheap so I replaced them and it did make a big difference.
Old 04-14-2003, 06:18 AM
Automotive Writer/DP
Randy W's Avatar
If MFI, you will at least want the spray pattern tested. You can have all of them cleaned and and then replace only those with a poor spray pattern - this finally fixed a surging problem at 4K rpm on my '72S and also improved a slight stutter at 6K on wind-up.
1972 S - Early S Registry #187
1972 T/ST - R Gruppe #51
http://randywells.com
http://randywells.com/blog
Old 04-14-2003, 08:10 AM
scottb's Avatar
Just before your next oil change, run a bottle of Techron through the fuel system. It made a big difference on mine.
1984 Targa
Old 04-14-2003, 09:57 AM
