-   -   Oil cooler or engine case leak? (http://forums.pelicanparts.com/porsche-911-technical-forum/1063669-oil-cooler-engine-case-leak.html)
Spark Chaser 06-10-2020 11:15 AM
jlex, one side of the repair area is accessible without removing the cooler. Unfortunately to repair the other side you will have to remove the oil cooler as highlighted in flojo’s previous post. I just did this on my ‘88.
Flojo 06-10-2020 11:47 AM
Originally Posted by jlex (Post 10899492)
But this would require taking off the oil cooler first, right?
to go 100% yes.
but you don't go through the husltle just for that check.
if you have a light leak, adress it next time you drop the engine for some other reason
proporsche 06-10-2020 11:56 AM
flojo........ your quotation is out of contest ..he was asking if he can see the outside of the case without taking the oil cooler off and the answer is yes you can see it without taking the oil cooler off..Just to clarify it for future onlookers;-)))))
Ivan
jlex 06-10-2020 05:27 PM
Larry: Sounds like it's a problem on the '88 too if yours has the original engine...
Url 06-17-2020 01:37 AM
What I did as I want to be 100% sure this area remains dry:
1. Sent out the oil cooler for pressure testing (Expected to have it back today)
2. Sealed the case with Versachem Titanium Epoxy System
http://forums.pelicanparts.com/uploa...1592381405.JPG
3. As there was a comment on the usage of green seals, I picked up new ones from the local Porsche center => For comparison (Big seal is a different green than the old one, suppose it doesn't matter but wanted to use new seals anyway)
http://forums.pelicanparts.com/uploa...1592381405.jpg
And while I was in there, I installed a new damping mat as the old one was completely dry and crumbling
proporsche 06-17-2020 04:20 AM
good job....
