no heat
just replaced blower motor, getting hot air to the heater valves but not up to dash, possibly plugged channels? how would you check that or if anyone has other ideas please feel free, thanks jeff '79,911 targa It also seems to get heat mainly on passenger side, and more flow when reving the motor, both heater levers do engage heater motor?
Old 04-12-2003, 02:51 PM
anybody?
Old 04-12-2003, 04:47 PM
first make sure that the levers are actually opening the valve, sometimes the cable breaks and thats that. if they are ok, check out the ventilation unit behind the dash and make sure everything is connected as far as ducting and control cables
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 04-12-2003, 04:57 PM
Hopelessly Addicted
Porschephanatic's Avatar
Porsche Crest
Was your car stored for any length of time over the winter? I found a rodent's nest plugging one hose 2 yrs. back. Now when I park the car, I pull the levers up and close off the bottom of the heater valves.
Could be as Jason suggested, cables and ducting. Once I found a broken heater hose (aluminum wrapped in brown paper) from the fan to one of the heat exchangers. My $.02
'81 SC Targa
'86 944
'49 Ford F-3
'13 Yamaha FZ-1 (Adrenaline Machine)
Old 04-12-2003, 06:35 PM
Erakad's Avatar
Having the same problem...just changed valves, exchangers and today the blower moter....some heat, but nothing to write home about. Should have checked the valves when I had it up on stands with the wheels off today...sigh, if you hit on a solution, let us know.
Rob
Black 1983
911 SC Coupe
Old 04-12-2003, 07:35 PM
well I just bought the car last october, the hoses to the valve weren't there, he told me he always stored the car. Cables I fixed already when i put on the hoses, thanks for the replies so far, next I guess I need to figure out how and what to try to run though there to see if its clogged, thanks again
Old 04-12-2003, 08:28 PM
fogcity's Avatar
Speaking of: On my 84 Carrera when I pull the right lever I get a terrible smell which comes in with the heat. The previous owner (who I'm discovering was less than honest) said that she spilled some dog kibble into one of the vents or whatever and hasn't had the chance to fish them out. So, where do I find these vents or whatever so that I can fish them (whatever they are) out?
1984 Carrera Coupe
Old 04-12-2003, 11:01 PM
ruf-porsche's Avatar
Dog Kibbles in one of the vent??????
What does it smell like other than terrible?
Does it smell like burning oil? Do you have any oil leaks?
Oil leaking onto the heat exchanger, Fix is to stop the leaks.
Does it smell like a dead animal decaying?
Could be a small rodent has climb into heat exchanger perhaps through the heater valve and die inside. Replace heat echanger.
Old 04-13-2003, 05:53 PM
Hopelessly Addicted
Porsche Crest
jeffk1, I just diconnected all the hoses and blew w/ air (shop vac/blower) from the front compartment back (so I didn't lodge debris in the front blower). You probably had critters in there if the car was stored w/out hoses.
'81 SC Targa
'86 944
'49 Ford F-3
Old 04-13-2003, 06:37 PM
fogcity's Avatar
Where's the heat exchanger?
1984 Carrera Coupe
Old 04-13-2003, 09:59 PM
Heat exchanger are underneath the car, they look like mufflers but are really headers with shrounding around them. The muffler is connected to the heat exchangers.
Old 04-14-2003, 05:22 AM
