-   -   1979 911 SC - problem (http://forums.pelicanparts.com/porsche-911-technical-forum/1063871-1979-911-sc-problem.html)
jjeffries 10-11-2020 01:38 PM
SC’s are excellent Porsche’s, I drive mine frequently and in all conditions. But just like a bad doctor can make you more ill then before you had an appointment with him/her, so too can an ignorant, unprepared or generally inept mechanic turn your SC into a problem car. One thing is for sure: it’s not your SC’s fault. An injection of common sense for the owner is what I’d prescribe. John.
boyt911sc 10-11-2020 02:05 PM
Had same thought.......
Originally Posted by john walker's workshop (Post 11060796)
You still haven't found a GOOD 911 mechanic, is all I can say.
John,
An hour ago, I wanted to say the same thing too but controlled myself posting it. It might be next spring before someone would figure this out. He has this problem for a while back and would exist until identified and corrected.
Tony
darrin 10-11-2020 02:52 PM
pc007 -- where are you located?
icarp 10-11-2020 03:32 PM
loose flywheel or pilot bearing , bad input shaft bearing, broken finger on pressure plate
You have to have someone else remove the engine and see what the other mechanic did or did not do
Ian
Pc007 10-13-2020 10:01 AM
thanks for the help...will get two...one for each
Pc007 10-13-2020 10:02 AM
Ian
done by 3 "specialists".... still does the same vibration...its also a mystery for them...
Pc007 10-13-2020 10:04 AM
hi Darrin, located in Europe...the car has been in 3 mechanics, 1 Porsche official, 2 very renown Porsche mechanics ....
Pc007 10-13-2020 10:05 AM
thats probably one of the problems, but I've been in the 3 top and renown in the area...one of them has been a Porsche mechanic for 50 years...so I've no more doors to open...
pmax 10-13-2020 10:06 AM
Is there any chance at all you can post a vid of the problem at the root of this saga ?
You have gotten the attention of the real experts in this forum !
gomezoneill 10-13-2020 10:17 AM
Post a video like 5 other guy's said. We can only guess with your description of the issue. The mechanics you describe as renowned can't possibly be if they can't figure this out.
Pc007 10-14-2020 05:31 AM
thank you all!! Ive got Porsches from 1962 to 2019 and as you can imagine, I've seen it all, had some problems to solve...but this car has been challenging!!
will try it to do a video ... car is at this moment at another mechanic for evaluation...but I don't know how it can be "seen"in video, reproducing the shudder is not easy.
just a curiosity, searching the forum I found another very similar problem ..car shudders/shakes when driving from still in 1st and reverse, car warms at speeds above 80/90 miles/hour, it was in a 2010 post!:eek: with zero answers...so don't know if it had a solution...sent PM to the owner just to try and see if he still looks at the forum and see if it reached a solution.
thank you all for your opinion and info! been learning a lot about the car at least!
Pc007 10-14-2020 05:34 AM
believe me Gomez, in my country there are few top Porsche mechanics...these are the best...ive now taken the car to a general mechanic that has done some good work in Porsche rally cars...been there for a few weeks...
I'll keep you guys posted until the solution comes!! i´m a stubborn guy!
keep some ideas coming !!
kenzinger 10-14-2020 02:04 PM
I've got a very similar engine shudder in all gears while accelerating, but mine is also accompanied by intermittent stalling. The tach will drop to zero and the engine will stall out, a few minutes and it will start right back up. I am hoping that they are related and that I don't solve my stalling problem just to face the situation you are in...
I am going to start with the cheap and easy Lambda relay, and then start looking at some of the ignition parts I think are original (wires, cap/rotor - all need to be done anyway).
This isn't like my Jeep where I can just throw cheap parts at it, so if the above doesn't solve, I'm picking up some gauges and going to start following some of the excellent CIS troubleshooting information in this forum.
Pc007 10-15-2020 12:02 PM
Good luck!! Keep us posted on the evolution
