-   -   Brake Bleeding - Could Use Some Help (http://forums.pelicanparts.com/porsche-911-technical-forum/1063979-brake-bleeding-could-use-some-help.html)
bbarrington 06-13-2020 10:47 AM
Yay. It's a happy ending. Brake pedal is firm. Clutch works. And no more sticky rear calipers.
It's enough to make you tired of winning.
ClickClickBoom 06-14-2020 11:13 PM
Change the fluid every other year. Brake fluid absorbs water from the air and that lowers the boiling point. More importantly the water will drop out of suspension and proceed to the calipers and once there will start corroding the interior surfaces.
I use these:
Introduction - Speed Bleeders - Russell Performance Products
I can bleed all 4 calipers by myself in little more time than it takes to access the calipers.
