Bump...Side mirror broke
While cruising today I hit a bump and the glass from my mirror fell off. Crap, do I really need to spend $120 on a replacement? Anyone have experience on how to replace ( ie part number, replacement how to, etc). Thank you.
Old 06-08-2020, 06:32 PM
Banned but not out, yet..
RSBob's Avatar
Mirrors are not held on with adhesive. Instead there are three clips attached to the back of the mirror with female receivers in the flag housing. No wonder it fell off. You may want to locate the three round receivers, clean them out and buy a proper mirror. You bought aPorsche, and parts come with a Porsche price tag. Want cheap, this is not the car to own.
Old 06-08-2020, 08:30 PM
Ahh...thanks Bob. That helps a lot. I'll buy that part and hopefully get it back on the road real soon. It was weird driving home without that side mirror!
Old 06-08-2020, 09:20 PM
sugarwood's Avatar
So what exactly are we looking at. The glass is missing, but the base is still attached?
1986 Bosch Icon Wipers coupe.
Old 06-09-2020, 02:45 PM
I haven't done any digging yet, but I suspect the PO glued a generic mirror to the mounting plate. I'll figure out the best way to remove the glue and post what I learn. I do love the adventure these cars provide on and off the road.
Old 06-09-2020, 07:58 PM
RSBob's Avatar
Just removed my mirrors last week. This is what the back of the mirror and receiver should look like
Old 06-09-2020, 08:06 PM
are the 944 mirrors the same?
Old 06-09-2020, 08:09 PM
I think mirror glass is held by an adhesive to the plate with the three clips on RSBob´s picture.
Old 06-09-2020, 08:39 PM
Still here
pmax's Avatar
Looks like you only need to find a mirror with the same dimensions which you can simply glue on and save $100 for a rainy day.
The other option is the used parts forum, post a WTB.
Old 06-09-2020, 09:00 PM
What year model is your Porsche ?
Give these guys a call
Replacement Car Side Mirrors - PORSCHE - 911 - Page 1 - MirrorGlassPlus.com
Old 06-10-2020, 08:51 AM
sugarwood's Avatar
How did PO get the glue to stay solid over the large oval hole?
Old 06-10-2020, 09:54 AM
The mirror is made of of two parts that are held together with adhesive. the mirror glass and the electrically heated (defrost) backing plate. It is fairly common for the old adhesive to fail and have the mirror glass shatter on the ground below. You can get replacement glass in both flat or convex that comes with double sided adhesive to stick back on in place of the original glass. readily available on eBay. because of the gap between the new glass and the heating element, the mirror defrost will probably not be as efficient as original, but the mirror will reflect again.
Old 06-10-2020, 10:36 AM
Still here
pmax's Avatar
Made in the USA as well.
Even cheaper here it appears
https://www.autoanything.com/mirrors/burco-side-view-mirror-replacement
Burco Replacement Mirrors are designed and manufactured in Grand Rapids, Michigan
Old 06-10-2020, 11:47 AM
Except for the flag mirror base (which has a different angle on the bottom to suit the door) I believe they're identical. At least for the electric mirrors of the same year.
'77 S with '78 930 power and a few other things.
Old 06-13-2020, 02:07 PM
