I will check it out, I have heard nothing but great things. They did the PPI on my car and were really thorough and walked me through everything on the car. They have also sold me countless parts at cost for DIY projects in the garage. Hope to meet you sometime. I have an 87 marine blue targa. |
1987 - It's Suspension Refresh Time!
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
Yep, it seems like it - always decisions and always while you are in there... I think the guys at Mayo will point me in the right direction. I just need something reliable and comfortable for a 3 day a week commuter and spirited weekend drives. I won’t be racing or tracking the car. What does the collective think knowing my use of the vehicle? |
Ok how much did you bet? You nailed it, the rubber center failed! And now I embark down the “while you have the tranny and engine dropped path” I changed out the fuel lines in the engine, I think I’ll have them tackle the tunnel fuel lines. I also addressed the triangle of death already so that is taken care of. Any other whole your in their items? |
2000 Boxster S and 2016 Audi A6 |
I think you could go either way on rubber center vs. spring center clutch disc replacement. It really just depends on how much NVH you're willing to risk / potentially live with. I went with spring center on both of my cars and I'm really happy, buy they are both weekend / sports purpose vehicles and not weekday commuters. I think you could also go with a lighter flywheel if you like (maybe depending on what condition your existing flywheel is in). Regardless I would have flywheel + clutch disc + pressure plate assembly all balanced as a unit. If Mayo doesn't take this step, I'd acquire that assembly from Patrick Motorsports as they'll balance it all before they ship it out. Besides that, I'd tend to any other resealing (chain box covers? Etc.) that may be needed. Should be SWEET once you get it back!
I’ll have to see what the flywheel looks like, I will be using it as a daily driver on nice days so I don’t want anything that will get annoying after a while. Previous to this issue there was definitely a lot of chatter at the friction point so I am not sure if that is more a clutch or a flywheel issue but they will be able to tell me I am sure. I have a pair of polygold bearings and rear springs plates that I’m waiting to put on it once it’s back. Sent from my iPhone using Tapatalk |
How many miles on that clutch before it blew?
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
Okay.... let's hope it's the number of miles, not the age of the rubber. Would hate for my 38,000 mi '88 to start acting up due to age alone.
The rubber center is what failed, so it’s possible yours could fail - but depending on how hard you drive it maybe not. After 30 years most rubber parts need to be replaced regardless of mileage. Sent from my iPhone using Tapatalk |
Functionista
88 911 with G50 trans does not have a regular rubber centered disc but it contains reinforcement limiting straps preventing too much drivetrain wind up angle so perhaps yours will have a long life.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. Last edited by manbridge 74; 07-12-2020 at 09:12 AM.. |
Nice bit of positive news there.... everything I've read talks about rubber centered disk. Sdgg91's picture sure looks to be packing lots of rubber... his is an '88 as well.
I am actually an 87. I didn’t know the 88/89s used a different setup. Great news for you! Sent from my iPhone using Tapatalk |
Jeff:
Is the '88 and '89 different from the '87? Sdgg91's looks like it's wearing a lot of rubber!
Still here
Sdgg91, what’s the build date of your 87 ?
Ok so it has been a while since I gave an update on this after receiving the vehicle back from Mayo. The build date of my car is 04/1987. So it turns out the car had never been opened up from what mayo could tell. it was in fact the original clutch at 127k miles. (Which tells me the car was never driven hard) which is great from my perspective. The downside was it needed the crosshaft update, as well as a new flywheel(aluminum), throwout bearing, Sachs clutch kit and new slave cylinder. I replaced the one J fuel line as well as the triangle of death while the motor was dropped. It wasn’t cheap and it ended up being $6200 for everything. BUT.. the car now shifts and drives like new and makes me want to drive it every chance I get! Sent from my iPhone using Tapatalk |
