 3D printing Aero bits (banana wing) Hello everyone, with the quarantine it seems that I´ve got enough time to finish several projects I´ve been putting aside in the last months, one of them is 3d printing some ideas I´ve had for the 911, led tailights, a "radio" bluetooth speaker adapter and in this case a functional wing for the track. so after spending a good amount of hours reading about aerodynamics, naca profiles, the NASA wing profile databe and of course turning that info into 3d models I came up with some options, first of all the (in)famous banana wing for which I´ve read in many forums and comments that is not the best alternative for a 911 because of the added drag but to be honest it is the one I like the most aesthetically so thats the one I started with, the beauty of 3d printing this part is that I get to test and try different options for a fraction of the cost of one wing. Of course this multicolor mess won´t be the finish of the wing since I plan on covering them with vacuum bagged carbon fiber but its nice to have the reinforcement of the ribs and the infill of the 3d parts as internal support. For anyone wondering the weight of the 3d printed wing is 2.6lbs which translates into more or less $20-$30 depending on the brand and type of PLA plastic plus around 80hrs worth of printing. best regards and stay safe Jake http://forums.pelicanparts.com/uploa...1592286572.jpg http://forums.pelicanparts.com/uploa...1592286572.jpg http://forums.pelicanparts.com/uploa...1592286572.jpg http://forums.pelicanparts.com/uploa...1592286572.jpg http://forums.pelicanparts.com/uploa...1592286572.png http://forums.pelicanparts.com/uploa...1592286572.png http://forums.pelicanparts.com/uploa...1592286572.png some LED tail light ideas I´ve been working on http://forums.pelicanparts.com/uploa...1592286572.png http://forums.pelicanparts.com/uploa...1592286727.png |
 Using a 3d printer as a base for a wing? That is a really good idea! Now I wish I`d had a 3d printer :) |
 Great job[emoji1303] Envoyé de mon iPhone en utilisant Tapatalk Pro |
 Cool  what large format printer do you have?   If you are looking for taillight ideas... Please print a stock tail light housing outer edge with a shallow depth profile designed for flat LED panels and STOCK lenses. I am a buyer. My printer is not large enough to make this. |
 Great idea will do, will keep you posted |
 Happy to collaborate on the light housing if you want. Send me a PM. |
 Awesome.  Look forward to seeing this come together! |
 Great looking project, I am also curious about your choice in printers, why the cr10 over the Ender 5 plus. I was about to buy a 5 plus, then Convid happen and they sold out. Supposed to be back in stock next week. Any advice on printers before I buy would be appreciated. Nice Work. Cheers, Tom |
 I kept thinking about your idea, made this quick mockups, will send you a PM http://forums.pelicanparts.com/uploa...1592344350.png http://forums.pelicanparts.com/uploa...1592344350.png |
 best regards Jake |
 I started with PLA but found PLA is very temperature sensitive and tends to twist like a pretzel under heat. But that was for small items. I moved then to ABS but ABS is difficult to work with and shrinks when cooling as it's designed to do so it pops out of molds after injection. ABS is difficult to keep on the platter. I ended up using ABS juice made from red or blue ABS mixed with acetone to keep the parts on the platter. The problem I've had with ABS is items with posts made from many layers tends to break easily although it is the most stable WRT temperature. I now use PETG for all of my printing for LEDs that I make. PETG is extremely strong layer-to-layer but still warps with temperature but not as much as PLA. If you want to do anything custom WRT LED panels give me a shout. I've been making 911 brake, reverse, turnsignal, and sidemarker LED boards for a while. |
 This thread has gotten off topic talking about tail lights, but I'd like to get in on the tail light conversation. I'd like buy or make 3D printed tail light housings with LED bulbs. I've started the CAD modeling but need to determine what material to print it front and what type and shape of LED's to run. http://forums.pelicanparts.com/uploa...1595521233.jpg |
 Another option is having the printed by somewhere like 3Dhubs using the MJF process. It is meant for industrial production and end use products. The surface finish is nicer than most printing processes and they can be tumbled or sand blasted. The best part is that the strength of the part is uniform and not different along different axes of the part so parts behave like a one part not a bunch of layers stuck together. That was long. Hope it helps though. Sent from my SM-G960U using Tapatalk |
 My plan is to print a prototype to work out the bugs and then get it printed professionally. I need to get with Spoke Works to figure out the LED size and location. |
 Interesting thread, some very good ideas and good work here.  Just a thought, some of the radio controlled guys are building their aircraft in carbon fibre/fiberglas/kevlar using molds built using 3D printers. It completely eliminates the concern about material strength, lets them put in inserts and such and generally looks pretty straightforward. They are using just single half molds and then join the two halves using resin/carbon tape and make some pretty accurate, pretty strong parts. Check out Ramy RC https://www.youtube.com/watch?v=h1TQBS1Wu3U Dennis |
 Hexcel corp. makes pre-pregnated lay up material and the hexagonal core also. wink, wink; got a plan to sneak wing mock up into work Autoclave when I can get away with it |
 best regards Jake |
| All times are GMT -8. The time now is 03:23 PM. |
