AEM A/F gauge toast?
Hey guys,
My AEM A/F gauge isn't working properly. When you start the car it appears to do a startup procedure, rolls through digits, then stops at 3 bars. Anyone see this before? I figure either the gauge or sender is toast. http://forums.pelicanparts.com/uploa...1592497633.jpg |
Mine did the same thing and it was the sensor in the tailpipe. I contacted AEM since it was fairly new and they sent me out a whole new unit.
maybe pull the sensor and try cleaning it up with brake parts cleaner, a softish wire brush & some air from a comprssor before you pony up for a new one. others have suggested soaking a fouled one in gas to clean them up.
It is suppose to do that when warming up and car not running. Unplug the sensor and it should read 14.7 . If so, gauge is good and sensor bad.
AEM got back to me and they say replace the sensor. I'll give it a clean.
Thanks 935. I'll try that as well. |
| All times are GMT -8. The time now is 04:59 AM. |
