Send a message via Skype™ to kyngfish
Winter Project Finally Done
For Father’s Day I finally wrapped up my suspension refresh after a torsion bar snapped a few months ago. Thousands of dollars in parts and blood, sweat, tears and more blood. She’s back. After finding the broken torsion bar I embarked on a seriously financially debilitating “while I’m in there crusade”.
Aside from the standard plugs - oil change - and cap and rotor. I also did a leakdown test - valve adjust - new valve cover gaskets - cleaned and painted the valve covers - sent the fuel injectors for clean and rebuild - new CHT - O2 sensor - speed sensor - ref sensor - new sway away torsion bars front and back - rebuilt and painted all calipers - bilstein sport rear dampers - hd front dampers - new front rotors - rebooted and repacked rear axles - cleaned and repacked front bearings - turbo tie rods - new ball joints - elephant racing a arm bushings and spring plate bushings - sway bar bushings - and set camber and toe and lowered at all four corners. Finally a wash and a wax.
I’m tired. But I’m glad she’s back in time for the beautiful PNW summertime.
Thanks to people on the forum prior threads and the incomparable DRACO - the only thing not done by my two hands was the fuel injector clean and rebuild.
Also. Huge hat tip to the URO parts folks. When I ordered the tie rods from them ages ago and they realized the rubber boots weren’t up to par they overnighted me better ones. They catch a lot of flak on here but I love that they are trying to help non wealthy diyers afford Porsche parts!
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250
Old 06-21-2020, 11:41 PM
famoroso's Avatar
Congrats! Looks good and I bet it feels great on multiple levels.
Broken torsion bar started quite the chain of events.
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 06-22-2020, 07:55 AM
Great leak down numbers ! That is where the nickies and proper brake in do there job.
Brake in with all rev ranges and red line and off gas decel and all throttle positions full and soft .
Lucky you!
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 06-22-2020, 08:21 AM
