1977 911 - Sunroof will not close correctly
The sunroof moves both directions ok
But it is at a slight angle , so it does not close . Any suggestions? |
Slippery Slope Expert
Pics?
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.” |
Joe Engineer just completes a sunroof repair. Check https://www.instagram.com/p/CBosb13F7Qf/?igshid=1s1e7xsi5h22g and his blog.
Here's some pictures .
Is this difficult to fix ? Thanks,Peter ![]()
Red Line Service
Broken cable.
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
The sunroof needs to flip just before it closes. Typically there is a problem when the plastic hinge? on the cable breaks. The only new ones are for later models so you have to file some part down a bit to get it to fit. At least the new ones are all metal so eliminates problem of plastic breaking again. There is a how to article on this.
1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993) |
Is this the right part ?
https://www.pelicanparts.com/More_Info/96456414400M100.htm?pn=964-564-144-00-M100&bt=Y&fs=0&SVSVSI=787 Assuming I need a left and right cable , that is over $400. :-( |
Disassemble first to see exactly what is going on. It's pretty straightforward.
Todd
'81 SC |
What Todd said. You may luck out and find that you can repair the cable where it attaches to the bracket. This post is very helpful: Sunroof cable repair and new seals 87 911
2000 Boxster S and 2016 Audi A6 |
Designer King
Open the sunroof 4" then unclip the headliner and push it partway back, exposing the mechanism. Check to see if the cable end has come out of its holder. People have been able to JB Weld and recrimp it back into place.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
I seem to remember paying about £35 ($50) for each but that was back in 2008. I bought mine from the local Porsche dealer here in Manchester UK. Sometimes parts from my local Porsche dealer are cheaper than after market parts.
