205/60/15 tire pressure
I have a 71 911T with 205/60/15 tires. As the size is not the original, I can't consult my owner's manual for the correct tire pressure. Anyone know? The temp is generally between 60 and 80 here in the Bay Area.
Thanks, John 71 911T |
Administrator
Hi johnr91122,
I did some searching and found this topic discussed a few times. I found this older thread specifically discussing 205/60/r15 which might help: https://forums.pelicanparts.com/porsche-911-technical-forum/976917-tire-pressure-205-60-15s-77-911s.html |
Thank you Matt!
I have been using 29F 34R with good success. No odd wear, rude not too harsh etc.
