STRANG roar in front
I am having problems diagnosing a noise with my 85 911. When goig down the road the car had a roar in the front right side...when i slightly turn the wheel to that side, it stops...only to start back later...
bw
Old 04-14-2003, 11:40 AM
my first thought is bad wheel bearing.
Old 04-14-2003, 11:44 AM
McDaniel's Avatar
Ditto
on the wheel bearing. And if the right is bad...the left may not
be far behind...
Impotence...Nature's way of saying "No hard feelings."
McDaniel
1974 911 Targa
1995 Toyota Avalon
2004 Toyota Tundra Extended Cab
Old 04-14-2003, 11:46 AM
Friend of Warren
definitely a wheel bearing
Kurt V
Old 04-14-2003, 11:56 AM
Adman's Avatar
Send a message via AIM to Adman
Add me to the wheel bearing diagnosis!
Matthew
Old 04-14-2003, 01:18 PM
me too!
206 637 4071
Old 04-14-2003, 02:26 PM
JWest's Avatar
You guys lack creativity.
I won't dispute you though.
James
JWest Engineering
Old 04-14-2003, 02:38 PM
nostatic's Avatar
lemmings...
bad enharmonic oscillator. They have to be replaced in pairs though. You can't just change out one with a spare. That's why I always carry 3 with me.
Old 04-14-2003, 02:49 PM
Senior Member
Superman's Avatar
No, the oscillator will only make a WHANG-ing noise, not a roar. Roars nearly always point to the sposkot plug, commonly overlooked. Pretty pricey though, so you should first perform the wind test, at operating temperature which means above 300 degrees F.
Mocha 1978 911SC. "Coco"
Old 04-14-2003, 03:29 PM
Muffler bearing. You just _think_ it's coming from the front.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 04-14-2003, 03:42 PM
nostatic's Avatar
you will only think the muffler bearing noise is coming from the front if your torsion shear bar has bad grommets. This will transmit the vibration from rear to front, thus inducing a counter-clockwise Bernoulli vortex. If however your enharmonic oscillator is functioning properly, the vibration will be nullified, and a clockwise vortex will counterbalance the muffler bearing.
Superman, I wouldn't perform the wind test unless you have recently replaced your thermowidget. And you also need to make sure that you have relays on your flux capacitor as the 300 degree mark can cause surges.
Old 04-14-2003, 04:39 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
HAHA nostatic I was just waiting to the flux capaciter to show up.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 04-14-2003, 05:30 PM
Bandwidth AbUser
Jim Richards's Avatar
Ya gotta re-chrome that muffler bearing...works every time.
What an incredible waste of my 1,000th post. Sorry!!!
Jim R.
Old 04-14-2003, 05:51 PM
CarreraCab's Avatar
Thats odd, the mid-eighties upon failing made a Wang-Chung kind of sound, the older models made a sort of a Acid-Wash noise, while the late models make a Rap-Rap noise !!!!!! Just get Herbal, and get in touch with your whatevers !!! Doug
Old 04-14-2003, 06:01 PM
Eric Coffey's Avatar
Sounds to me like a bad Quetzel-Quatel diaphragm retaining seal.
Old 04-14-2003, 06:53 PM
What?
trj911's Avatar
Sounds like bad gas to me!
Tom J.
911SC Cab
SCWDP
CaymanS
Old 04-14-2003, 07:31 PM
nostatic's Avatar
Actually the Quetzel-Quatel seal can be hurt by bad oil, not gas. Best to taste a bit of each to make sure.
Old 04-14-2003, 09:04 PM
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-14-2003, 10:17 PM
nostatic's Avatar
ah, but Ron your emoticon wouldn't be smiling if there was QQDRS dissolved in that bottle...nasty stuff!
Of course it would be fine if that coozy around the bottle is actual a "Cruel Collar". That product has been shown to decrease QQDRS, FC, and BV contamination by up to 50%.
Old 04-14-2003, 10:20 PM
Cool
no kidding.. I didn't know that.. I gotta get in my 911 and adjust the nut behind the wheel before it spins a bearing.. I need info on that project.. help...........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-14-2003, 10:25 PM
