Porsche 911 SC - Green oil indicator + Brake indicator flashing syncronised?
Hi everyone,
I've got a really weird problem with one of my Porsche 911 SC's from 1978.
Recently is has begun to flashing the green oil indicator and the Brake indicator at the same time. They are flashing synchronized and also the intensity are following each other, totally synchronized. It seems very weird.
Since it's the green oil indicator flashing, I've not dared to drive any trips. So my observation are only during start-up and for up to 3-4 minutes. The synchronized flashing of the two comes as goes, sometimes there's 5-15 seconds between the flashing. There's not an apparent connection between pushing the accelerator, when trying it.
Does anyone have had a similar problem? And if yes, how did you fix it? Or perhaps you have some good ideas to what can be wrong?
Any help is much appreciated.
BR
Chris
Old 06-24-2020, 03:18 PM
No one ever tried anything similar? :-O
Old 06-27-2020, 04:06 PM
Any recent work on the back of the gauges? Bulb replacement? Do you have a loose ground wire somewhere? Any other wires that may have popped off the back of the gauge?
Old 06-27-2020, 05:42 PM
What's the oil pressure gauge read during this? No correlation I'm sure just curious.
Old 06-28-2020, 06:55 AM
