ARGH...transmission positioning spring missing
Reposting since I put it in the wrong forum...
Hi All: I'm restoring a 1977 Targa 911 - and thank everyone on the forums so far for their invaluable help! I had the Wevo shifter put in, which works wonderfully from the old oatmeal search and find gearing previously. The car shifts ok, but occasionally grinds when going into second. So today I went under to look at the tolerances, ready to potentially adjust the stop screw to the 1.2 and 1mm distances. Angst ensued (and disappointment that my mechanic didn't find this) - there was no positioning spring attached to the positioning arm. And of course, the bolt was therefore flush with the positioning arm. An order to our hosts is in route, but anything I should now be evaluating given this finding? TIA. |
Hello there!SmileWavy
I'm Rudy with Pelican Parts, let me know if this is the missing spring: https://www.pelicanparts.com/More_Info/91530323200OEM.htm?pn=915-303-232-00-OEM&bt=Y&fs=0&SVSVSI=788 |
Hello there,
Thank you for being part of this community, I would like to share a relevant link that might inform you better about the Wevo shifter installation and any nuances about it: https://bit.ly/wevoshifterinstallation |
Thanks - it's the transmission positioning spring - and it's back ordered. Much appreciate the response. Best, Bert |
Bert |
When was the last time your gearbox was rebuilt?
Sent from my iPhone using Tapatalk |
| All times are GMT -8. The time now is 10:11 PM. |
