| Registered |  driver car door locking
			1987 Carrera when inserting the key to lock the driver door, the click sound is there for both lock and unlock BUT the door does not lock up... The passenger door works just fine. Any thoughts as how should this be remedied? | ||
|  06-29-2020, 02:39 PM |
| Registered |
			Most probably the plastic ball socket has broken thus no lever action.  I replaced mine with this.  Same thing. Get two. https://www.pelicanparts.com/More_Info/99916802140OEM.htm?pn=999-168-021-40-OEM&bt=Y&fs=0&SVSVSI=819 Note: the original was white, or yellowish after 30 years. Last edited by mo-mon; 06-29-2020 at 03:08 PM.. | ||
|  06-29-2020, 03:05 PM |
| Registered |
			Mine did that and it was the "Door lock actuator/operating rod"
				__________________ 1987 Porsche Carrera Coupe | ||
|  06-29-2020, 04:34 PM |
