Rodent nest urine odor in frunk
Is there a commercial spray-on or soak in product that you can apply to the lining material in the frunk after a winter of rodent nesting ? Google questions seem to return advice on disinfecting the area and advise to use a mix of bleach and water. I am more interested in eliminating the smell. Could I take the linings out and stick them in a clothes washer with a dose of bleach? Leaving them out in the sun does not do the job. Thanks in advance for any help/advise.
Old 06-28-2020, 04:39 PM
'73 911 T Targa
If you have a janitorial supply nearby, see if they have an enzymatic urine odor eliminator. I used it once and it worked like a champ. If you don't have a janitorial supply, a pet store will have something, but I think the professional stuff is better.
Old 06-28-2020, 04:56 PM
Inaminit, we are very sorry to hear about the rodent situation, here are some links that could help you with the odor:
https://bit.ly/Pelicanautoparts
https://bit.ly/InteriorCleaningPelican
Hope this helps.
Old 06-28-2020, 05:24 PM
El Duderino
tirwin's Avatar
Another idea is to try an odor eliminator spray. I found this stuff that was made for removing smoke odor but it works really well at neutralizing just about any odor.
I’d try the urine eliminator first. If that doesn’t work, try this.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 06-28-2020, 07:17 PM
The OEM and/or hi-quality replacement carpet will take an easy wash, I believe. Lay the three pieces out on the driveway. Soak them with a garden hose. Use a little Tide or any laundry soap and scrub gently with a bristle brush. Rinse thoroughly and hang it up somewhere to dry. When it's dry you could spray with the anti-skunk fru-fru, but prolly not necessary.
Old 06-28-2020, 09:03 PM
Vulnerari Praesidio
I think that the only solution you will be happy with is a new liner.
"Wisdom is knowing what to do next; virtue is doing it."
- David Starr Jordan
Old 06-29-2020, 09:37 AM
You could try citronella.
The liquid version of what they put in bug candles takes away smells with a few small drops .
If not , in the past I’ve used febreez in the past in cars to some effect
Old 06-29-2020, 10:47 AM
77 Restorer
+1 Febreeze. May take a couple of applications after nests etc are gone.
Bert
77 911 Targa (Maize, or Talbot yellow as the case may be)
04 C4S Cabriolet (sold)
Old 06-29-2020, 12:00 PM
Any pet store will have a carpet cleaning product specifically designed to remove urine stain and odors. I would lay it out on the garage floor and use a carpet cleaner if possible.
Old 06-29-2020, 12:41 PM
Pelican Parts Vendor
UROParts's Avatar
Get an enzyme solution designed specifically to break down urine, like this Nature's Miracle P-98151 Dog Stain and Odor Remover. It even works on cat urine. It also comes in spray bottles, and you can use soaked cloth or paper towel to help keep it on vertical or angles surfaces while it does it's thing.
Most "air freshener" products don't actually remove odors, they just temporarily deactivate the human sense of smell so you think the odor is gone. Also read up about the endocrine disruptors found in many of these products: https://www.niehs.nih.gov/health/materials/endocrine_disruptors_508.pdf
URO Parts Online Catalog for Porsche: https://apaindustries.com/catalog?make=2
Old 06-29-2020, 04:36 PM
Hydrogen peroxide works really well on urine etc.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 06-29-2020, 05:34 PM
Vetoquinol Equalizer Pet Stain & Odor Remover. I've been happy using it for 30 years in my business.
Rick
1978 911SC
Old 06-29-2020, 06:37 PM
Replace the carpet and put it in your rear view mirror.
Old 06-30-2020, 07:34 AM
