Fuse question
I've looked and couldn't find anything definitive (if it even exists), but does anyone know of a diagram that shows the exact label of the fuses/relays in the frunk fuse panel for a 1987 930? I've removed several things like the radio, fresh air blower, footwell blowers, alarm, etc and would like to see about removing unnecessary fuses.
Frunk Fuse Box Label
This is from a 1988 Carrera. I don't know if it's the same as one for a 1987 Turbo, but it should be close.
http://forums.pelicanparts.com/uploa...1593542277.JPG |
There should be a label inside the fuse cover. You may be able to see on the wiring diagram as well.
You face a couple of dilemmas. Porsche was changing the wiring depending on options and updates to the cars. And who knows what a PO did? |
See the wiring diagram page 1
http://911c1.de/porsche/Schaltplaene/plaene1-10_carrera_32.pdf Sent from my iPad using Tapatalk |
Perfect, thanks guys. A bunch of gentlemen and scholars...
| All times are GMT -8. The time now is 09:19 AM. |
