-   -   Pls Confirm Where to Pry Apart 14 Pin Connector (http://forums.pelicanparts.com/porsche-911-technical-forum/1066022-pls-confirm-where-pry-apart-14-pin-connector.html)
Paulporsche 06-30-2020 04:34 PM
I've read about people breaking brittle plastic and losing pins so I want to get this right. Do I merely pry apart the 14 pin connector along the line between the red and yellow arrows? Note: pic is not from my car.
Thanks.http://forums.pelicanparts.com/uploa...1593560040.jpg
blucille 06-30-2020 04:47 PM
Yup, it truly is that simple....I don’t see much risk of breaking anything unless you try to pry the red side or the yellow side without trying to separate it from both sides somewhat evenly.....I’ve never even thought about a risk of breaking it, it’s pretty tough....they’ve all come apart easily for me.
Paulporsche 06-30-2020 06:56 PM
Thanks blucille.
T77911S 07-01-2020 07:41 AM
that's where it separates.
it should come unconnected pretty easily.
the "cap" on the right side of your pic can come off is you need to do some rewiring inside it.
3rd_gear_Ted 07-01-2020 01:42 PM
If caps come off connectors, individual connector pins will try to come out.
Be prepared
Been there, done that
Paulporsche 07-01-2020 07:28 PM
Thanks Ty and Ted.
Yes, I need to replace a broken yellow wire to the TTS. It broke just outside the connector housing.
bkreigsr 07-02-2020 10:54 AM
You haven't met my gorilla mitts yet.
Anything plastic, or a plastic derivative seems to deteriorate by just my looking at it.
Bill K
