Sunroof Wind Deflector Installation - help required
Having purchased a replacement kit, made of metal so expensive that the car's value has just doubled, I'm loath to attempt installation without any instructions or guidance. I've search the web and can't find anything showing the process from end to end. The kit is one of those Golde replacements (3 deflector pieces, 4 hinges and 2 springs) going on a SC. Any help would be greatly appreciated. Cheers
Took my entire car apart down to bare shell. 79 SC. The wind deflector simply screwed out and came out piece by piece. Don’t recall anything tricky at all about taking it in or out. Did also replace the felt pieces that were under it. You may want to have those on hand as well.
Thanks for the reply. Did you dismantle the deflector; hinges taken off spring? I have new springs and new hinges. It's the install of those bits that I'm concerned about. Cheers
Thread Tools | |
Rate This Thread | |
Tags |
911 sc , deflector , sunroof |
