Lower idle while 85 3.2 is warming up
My 3.2 runs great but must warm up about 5 minutes or it will die at a light. After 5 minutes it is fine. Also , if I start the car from cold in the garage it warms up correctly. All vacuum leaks were fixed on top end. Idle is correct at around 8.5. Thank you.
Old 08-29-2020, 05:41 PM
proporsche's Avatar
fuel mix....a little too rich...take it to the guy who did your engine recently
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 08-29-2020, 11:24 PM
My 3.2 used to stall occasionally when cold. For example, it would occasionally stall
shifting from first to second following a cold start. I replaced the idle control valve and the issue disappeared. Try cleaning your ICV first and see if that helps.
Mark
Old 08-29-2020, 11:35 PM
Thank you! But Ivan , the fuel mixture is set by Motronic!
Old 09-02-2020, 10:47 AM
Brew Master
cabmandone's Avatar
Not really, you can set the base idle mixture but you need to make sure the car is warmed up and you have something to read AFR's while making the adjustment to the idle mixture screw on the bottom of the AFM.
Nick
Old 09-02-2020, 11:40 AM
I talked to my Porsche mechanic and he said idle is set by motronic. Those other settings may make motronic work less hard .
Old 09-02-2020, 12:22 PM
proporsche's Avatar
nick, you are really in a dream land.There is a setting for the fuel mix by factory standards if you thing otherwise that is your problem;-) you always make me laugh with your statements;-)))) Just think for a minute..why would the official Porsche manual tell you how to adjust the fuel mix if it would that easy so the motronic will do the work..good luck solving your idle problem;-) and i mean it....
Do some more reading it will help you
Ivan
Old 09-02-2020, 01:04 PM
I have been doing reading. And what I find is that motronic sets the idle. From lots of sources.
Old 09-02-2020, 04:53 PM
Idle and motronic
Check this out.
Old 09-02-2020, 05:07 PM
You have a different motronic on your 3.2. There are no knock sensors. The above wiki is for the 964 & 993.
Old 09-02-2020, 05:20 PM
Thanks! Motronic in 3.2 still sets the idle.
Old 09-02-2020, 10:00 PM
proporsche's Avatar
nick , the idle is set by idle control valve(plus manual screw) and the fuel mix on AFM is set by the adjusting screw..
good luck;-)
Old 09-02-2020, 11:11 PM
Originally Posted by proporsche View Post
There is a setting for the fuel mix by factory standards if you thing otherwise that is your problem Just think for a minute..why would the official Porsche manual tell you how to adjust the fuel mix if it would that easy so the motronic will do the work..good luck solving your idle problem;-) and i mean it....
I'm with Ivan. You've got to get the mixture right!
My 3.2 was super rich at idle when warm with AFRs in the 10's. It stunk of fuel and would hunt and struggle when cold because the Motronic is just throwing extra fuel in regardless. I tried adjusting the AFM screw out but even with 8 turns out it made little difference even though my O2 sensor and Motronic are fine. Someone had opened my AFM previously and altered the spring so I carefully tightened it one cog at a time and monitored AFRs out on the road. Turns out two teeth is all it needed and with about 1 turn out on the AFM mixture screw it idles at AFR 14.4 when warm. Starts and runs beautifully from cold now. Yours just might need some adjustment to the AFM screw though.
It's a standard tuning issue that should be done every year or so and when you replace an O2 sensor. Check and adjust mixture via the AFM screw and adjust idle speed with the idle control valve jumpered from the port in engine compartment. Only takes a few minutes to do but makes a huge difference to idle and part throttle behaviour. I think a wideband Air Fuel Gauge should be part of everyones garage equipment.
Davin
'87 Carrera 3.2
'66 VW Camper
'59 VW Beetle
Old 09-03-2020, 03:55 AM
Brew Master
cabmandone's Avatar
If you'd like I can do a video of me adjusting the idle mixture. I have an onboard AFR gauge and when adjusting the screw on the AFM it does indeed make the idle mixture rich or lean depending on he way the screw is turned.
Do yourself a favor and look up "base idle mixture". It might help you understand where you're mistaken.
Not saying this to be a jackass but I'd find a more knowledgeable Porsche mechanic if that's what he said. Setting the base idle doesn't make the motronic work easier, it sets the mixture so the motronic works properly.
I can raise or lower the idle speed with the screw on the throttle body and I can adjust the mixture with the screw on the AFM.
As mark suggested, you might try cleaning your IACV.
Nick
Old 09-03-2020, 04:56 AM
Ok, here is the deal, true, we can adjust the base idle ! But the regular idle is controlled by motronic . It’s in a article right here on pelican!!! BTW, I have shop manual, I know how to adjust the mixture with plug and jumper wire. My car just passed California smog in San Diego! I have a extra ICV, I’ll change that out. Don’t want to mess with settings when car runs so well.
Old 09-03-2020, 10:36 AM
