markmalin's Avatar
How do I press in the door stay pin?
I replaced the driver's door stay mechanism and installed a reinforcement plate. I bought a new pin but I can't seem to force the pin in all the way. I see if I try to put the pin in the original door stay, it only fits in part way (the narrower end). The upper end is ribbed, which I assume secures it into the door stay arm when it's put in properly What's the procedure for pressing this in? I've tried just pressing on it by hand, with a pliers, tapping on it with a hammer and a drift, but don't want to damage the part that's connected to the body of the car.
Mark
Mark - New Glarus, WI
Old 01-19-2021, 09:28 AM
Door stay pin........
Apply some heat around the hole and compress the pin using a C-clamp and a suitable socket. Store the pin in the freezer before installation and it will slide easily.
Tony
Old 01-19-2021, 09:46 AM
markmalin's Avatar
Tony
Thanks!
Old 01-19-2021, 09:47 AM
I toss those damn things and use a 6mm bolt and nylock nut. Never had much luck getting them through without undue violence.
206 637 4071
Old 01-19-2021, 02:12 PM
markmalin's Avatar
you know...that's not a bad idea. The holes in the part that's mounted to the body of the car have been enlarged over the years while the hole in the stopper arm is smaller. It makes an annoying snapping sound when the stopper arm detents are passed because the arm snaps forward and the pin hits the inner edge of the enlarged holes (if any of that makes sense). I should just try a 6mm bolt and nylock to see if it works any better. The other side I see someone used a roll pin on - it's dead quiet!
When I installed the new stopper I even dismantled it first shaved down the plastic/rubber bumpers that ride over the arm's detents hoping it would be quieter...
Old 01-19-2021, 02:22 PM
markmalin's Avatar
John, I went down to the hardware store, got a stainless allen head M6 bolt, a nylock nut and a couple nylon washers. Worked like a charm! I ended up wrapping some teflon tape on the threads and added a couple layers of copper tape so it would fit snugly, tightened it down and it's dead quiet. It has NEVER been that quiet before
Old 01-21-2021, 02:12 PM
oh.. so THAT's what's making the clicking noise every time I open or close the door.. I think I will look into doing a similar thing.
Old 01-22-2021, 09:22 AM
I agree with the bolt method. On other cars I have filed down the splines a bit to get them in easier.
Old 01-22-2021, 09:27 AM
markmalin's Avatar
YES!! This has driven me nuts for years. Watch the pin as you open the door. The pin is tight against the door stay arm, but loose against the holes attached to the body - the pressure from the detent inside the door stay slams the pin into outer edge of the oversized holes in that part that attaches to the body. (I need a better name for that thing....sorry)
Old 01-22-2021, 09:41 AM
proporsche's Avatar
i always used hammer and it worked.....
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 01-22-2021, 09:42 AM
markmalin's Avatar
here's a picture. I have a nylon washer on top of a rubber washer FWIW
Old 01-22-2021, 09:49 AM
I use a bolt and nylock nut, nothing else. Tighten until it stops snapping and snug it up down the road as needed.
206 637 4071
Old 01-22-2021, 10:04 AM
Mark
Maybe the hole, has to be reamed for the pin...that's what i would do.
Old 01-22-2021, 10:19 AM
I did this fix today...to stop the snapping sound.
Awesome fix...it's silent now. The total cost was $1.84
Thanks for the tip!
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 01-23-2021, 09:00 AM
Thanks John, the noise was bugging me for years. Ran out and bought the cap screws and they work like a charm.
Old 01-24-2021, 10:19 AM
Thanks for saying this. I'm now clear to replace with small bolt and nylock.
Sold: 1989 3.2 coupe, 112k miles
Old 04-22-2021, 07:48 AM
Flojo's Avatar
just grind down slightly the corrugated area until it slips in kinda by itself.
so easy.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 04-23-2021, 04:46 AM
The nylock bolt procedure corrects Porsches original inferior design. Improving on Porsches design is a good trick it you can do it.
Old 04-29-2021, 12:45 PM
