budget emissions fix
I'm trying to pass CA smog, but my Co2 levels are running high. Part of the problem is that the car is registered and tested as a 77 911sc, but engine is actually the 3.0L from a 79sc. Was thinking maybe I need a more powerful coil or aftermarket ignition? Any recommendations that won't break the bank? thanks!
Old 07-09-2020, 07:52 AM
Can't fix co2. You mean co? If so, adjust to run a little leaner. More spark might help if your ignition is out of whack. Start with adjusting cis first
Sent from my Nokia 7.1 using Tapatalk
Old 07-09-2020, 08:00 AM
