Hello everyone, I´ve got this wheel from an old 74 bmw 2002 project I had and was wondering about using it in my build but wanted to find out more about it, If any of the wheel guru´s in here could help me it will be greatly appreciated
best regards Jake ![]() ![]() ![]()
"It's only temporary unless it works" 1974 911s turbo-look stock 2.7 engine "Dirty Martini" 1953 replica 550 spyder built from the ground up, EJ25 engine Speeduino ECU |
Driver
Is this a trick question? Is that not a Momo stamp (manufacturer) with a Jacky Ickx signature (edition)?
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Wasn´t a trick question honestly, I knew about the momo but the number on the back apparently has lots of matches including some OEM ferrari wheels, I just found out about the signature edition, and you´re absolutely correct thank you!
I believe the “M 20340” indicates this wheel was produced from 1974-76.
