Car horn goes off continuously when pushed
My car horn will go off for 15-20 seconds even if I just tap on the horn. Does anyone know what might be wrong? Thanks in advance
Old 08-13-2020, 11:27 AM
what year?
'79 911SC Targa
Old 08-13-2020, 12:09 PM
Spring ground contact........
The ground contact is stuck. Inspect the horn button and look for the brown (or black) wire that makes contact to ground. The brown wire (ground) contact point is not retracting after you pressed it down. Look for a spring with brown wire and start from there.
Tony
Old 08-13-2020, 12:16 PM
I'm good with tools.
AG81's Avatar
My mom would say..."Then don't tap it. If you leave it alone it will be fine"...........
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 08-13-2020, 01:16 PM
'73 911 T Targa
On mine, this button had degraded over time.
https://www.pelicanparts.com/More_Info/91434783100M260.htm?pn=914-347-831-00-M260&bt=Y&fs=0&SVSVSI=5878
Note that there are several different types.
Old 08-13-2020, 04:32 PM
Tags
911 sc horn
