Bilstein struts dust cover
Hello everyone
Just finished rebuilding my Bilstein struts for my 82 SC. I purchased the B6 inserts from our host as well as elephant racing caps. My question is, should there be something that goes over the strut insert Before I slide the dust cover onto the strut. From diagrams it shows some kind of a spacer but I’m not sure. Note the raised section just before the threaded aspect near the 3nd of the strut insert. Thanks in advance. ![]()
Nothing.
Great
Thank you John PS. I tried sending you a message a few weeks ago. You needed a throttle body for a late 914. Do you still need one? I can mail it to you. |
I was trying to help another local shop, Akers, and they probably still need one. For a 912E. May be different than a 914 2.0.
I have a small rubber spacer that came from Elephant with my B8's that I'm installing in my '75s. Should I not use it? I thought it went between the strut insert and the dust cover. Thanks in advance.
No, toss it. Just keeps the cover on the insert when it's in the box.
Perfect, thanks John!
