Slumlord
Porsche_monkey's Avatar
Unhappy Wiper Fluid Reservoir
I am restoring a 74 911 with Turbo front flares. The wiper fluid reservoir is obviously below the driver headlight but:
1) the fill tube is in with the gas cap, a 3/4" hose runs over to the reservoir, and it appears to be impossible to fill without spilling about 99% of my fluid, what the heck is this?
2) the pump is close to the battery , above the reservoir, but there is no check valve in the bottom of the pick up tube, only a screen, meaning that the line would drain back every time
3) I haven't even thought about the headlight washer yet and already I'm in trouble!
Any help / pictures around?
Old 04-16-2003, 10:08 AM
Use a funnel to fill and the check-valves are, typically, in the lines just before the squirters. Can't help much with the headlight washer, the ones I've seen (later models) use a different reservoir with the headlight washer pump mounted in and near the bottom of it.
Jerry M
'78 SC
Old 04-16-2003, 10:42 AM
Slumlord
Okay, seems weird to me to require a funnel, but I guess I have it right, thanks for your help.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 04-16-2003, 10:43 AM
