911, 914-6, 928
Engine Shop recommendation - Michigan
I have aircooled mag case 2.7L based performance engine that needs reassembly after a reseal tear down. I'm looking for an experienced and competent individual or shop in the Detroit metro area (SE Michigan) who can do the work at a reasonable cost and timing. Cases were not split, and at this point no machining should be needed. Most parts are on hand. Heads are freshly rebuilt, so assembly of pistons/rings/cylinders/heads/cams/chains/etc. is what I have in mind.
ANY RECOMMENDATIONS?
Old 07-12-2020, 11:48 AM
Try Automotive Techniques in Novi and ask for Tim Pott. He is very knowledgeable and knows Porsches inside and out. Example of Tim’s vast knowledge. https://derfixtech.com/wp-content/uploads/2019/07/Getting-to-Know-Mr-Mezger-1.pdf https://automotivetechinfo.com/wp-content/uploads/2019/11/Mezger-Engine-part-2.pdf
Old 07-12-2020, 07:55 PM
