7783911's Avatar
position of OEM Fog Mounts
Could someone with a G body 911 (1977) please measure the distance from the center of the valence to the inside edge of the mounting bracket so I can install my new old fogs correctly
Also include measurement from top of valence to top of flat bracket please
thanks!
Old 07-13-2020, 04:58 AM
Poopwink's Avatar
I think you want a pre-1984 911SC specifically, as I believe on the '84 SC the fogs were mounted flush instead of protruding. All the 3.2 Carreras I've seen share this update.
Old 07-13-2020, 03:18 PM
7783911's Avatar
yes, mine is a 77 targa
so i have the offending brackets removed from non oem fogs...looking at the valence there is a flat spot on both sides in about the same location as the old fogs
this is where i figure the real oem brackets are attached but was hoping someone could give me exact center to mount length?
anyone? please....
Old 07-13-2020, 04:23 PM
I just measured my 78 targa. 37.5" center to center.
2.5" top of valence to flat part of bracket
Old 07-13-2020, 05:54 PM
7783911's Avatar
Center to center?
What is measurement from ? Center of valence to center hole of bracket?
Just confirming
What is position of bracket center hole from top of valence
Thanks so much!!
Old 07-13-2020, 07:41 PM
Just confirming
Thanks so much!!
The 37.5" is center of foglight to center of other foglight, measured at center dimple on bottom.
The 2.5" is from top of valance to the top of flat as marked in your drawing. But, my valance top looks closer to my bumper than yours.
Old 07-13-2020, 08:25 PM
7783911's Avatar
Thank you!...wiring all set, now to mark up and drill the holes...mount and another project completed
bob
Old 07-14-2020, 03:18 AM
