915 Trans Speedometer Sensor
My car is a 914 but since the engine and transmission are both from a 911 I figured I'd post my question here.
I'm having issues with my 915 transmission and need to pull it from the car. While unhooking things under there I was surprised to find this sensor on the passenger side (drivers in a 911). My case is a 915/63 but I believe this is the speedo sensor from the last generation of the 915 (915/73). My speedometer has never been hooked up because I believed I needed to mill out a spot on the case due to the pinion gear being flipped for a 914. But the sensor for my case is different and would be on the drivers side. Does anyone know if the sensor that is there will work of i trace the wires and hook it up or does it need to be moved due to the flipped gear also? http://forums.pelicanparts.com/uploa...1594647554.jpg |
your cross post was answered on 914World by Luca
I believe that is a G50 sensor with that retainer.
Bruce |
| All times are GMT -8. The time now is 09:12 AM. |
