-   -   Help identifying a connector (http://forums.pelicanparts.com/porsche-911-technical-forum/1067187-help-identifying-connector.html)
Robcat77 07-13-2020 11:53 AM
Greetings everyone.
On my 1984 3.2 Carrera, I recently came across a little debris in the engine bay. Turns out it's some degraded insulator plastic or rubber from this connector. Can anyone tell me what it's for? I re-connected the male/female end and is now being held together with a zip tie.
I thought it might be for the oxygen sensor, but my Bentley manual shows that to be a three-prong connector.
http://forums.pelicanparts.com/uploa...1594666199.jpg
FrankM_ 07-13-2020 12:25 PM
Yep,
That is the O2 sensor. They changed to the 3 pin connector in late 85.
Kroon make a new plug if you wantto keep it orig
Robcat77 07-13-2020 12:30 PM
Perfect - thanks.
I'll see if I can't find the Kroon connector.
I've discovered that a bunch of these older rubber/plastic bits have become very brittle/crumbly. To be expected after 36 years of engine heat, etc.
FrankM_ 07-13-2020 01:16 PM
https://www.kroonwireharnesses.com/porsche-911/porsche-911-1984?product_id=747
