911r tail light install help
How are you installing the hella lamps onto the housings?
If my thinking is correct. I’m planning of cutting a 68 mm hole in the housings that will allow the grey backing to push through just enough to screw the lenses on sandwiching the housing in between. Is this right? Thanks |
| All times are GMT -8. The time now is 10:40 PM. |
