Is it possible to mount flares too far forward?
Picked up this 72 as an abandoned project. Have the mechanicals decently sorted so now on to paint and body. The car has glass RS flares, my question is the position of the rear wheel in the arch, normal?
I would rather be driving
Something is not right there...
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
It looks like lwb flairs on a swb car but this is a 72.
Does it look like the torsion bar lines up with the torsion bar hole in the flare ?
Maybe they tried to eyeball it without mounting the wheel and having the suspension unloaded.
Walt 82SC 3.0 81SC 3.6 Last edited by walt; 07-15-2020 at 01:05 PM.. |
There are at least a couple of old race cars out there with altered wheel bases that moved the rear wheels further back in order to get more weight on the front end and reduce the oversteer problem. Watch this video. Jim Busby starts talking about 4:58 into the video.
https://www.youtube.com/watch?v=hfq7-1ePW-M |
This is the bumper, so this would have to move forward several inches too correct?
True , but the rear wheel on this are in ....
Is it all fibreglass ?
Take a pic of underneath showing your arms , and the mounting points .
Under the radar
What size tires are those? It looks like the tires are shorter than stock.
I would take some measurements from a stock car and see what is going on. I almost used FG fenders on my car.....
It looks like the rear bumper is glass too , that’s why I asked .
It’s pretty easy for an “artistic amateur” to make fibreglass go wherever you want , so if said amateur put fenders on in wrong position they’d simply modify the bumper ends to suit . Pics of insides of a rear bumper end should show if it’s been cut’n’shut at all .. |
There was a car for sale on Bring A Trailer a while back with a similar problem , having used GT racing panels on my car i,m praying i don't have the same issue when I get everything assembled .
Ayo Irpin, Ukraine!
SWB trailing arms???
Harmlessly passing gas in the grassland away; Only dimly aware of a certain smell in the air |
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud) '70 914/6 Race Car (Faster and Louder) '71 73RSR tribute vintage race car 3.0 '68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox '81 Magenta IROC clone in progress 3.6 varioram/G50 |
So where is the actual spring plate center relative to the torsion bar access hole in the flare?
This will tell you if the flare is relatively rearward compared to its supposed location. Looks like it also may be hung low.
I’m thinking there might just be a mechanical problem and a bodywork problem , hence my request for more photos .
It’s easy to say the fenders are out , as the Torsion bar holes are nowhere near . But looking at an lwb dead on the side-view , edge of rear 1/4 windows lines up with side of Fuchs center-cap . It’s an angled photo so harder to see this and easier to get photos of rear arms as I asked , But swb -lwb arm difference is about 60mm ..... |
