Is it possible to mount flares too far forward?
Picked up this 72 as an abandoned project. Have the mechanicals decently sorted so now on to paint and body. The car has glass RS flares, my question is the position of the rear wheel in the arch, normal?
http://forums.pelicanparts.com/uploa...1594838031.jpg http://forums.pelicanparts.com/uploa...1594838083.jpg http://forums.pelicanparts.com/uploa...1594838124.jpg http://forums.pelicanparts.com/uploa...1594838156.jpg http://forums.pelicanparts.com/uploa...1594838189.jpg |
Something is not right there...
It looks like lwb flairs on a swb car but this is a 72.
Does it look like the torsion bar lines up with the torsion bar hole in the flare ?
Maybe they tried to eyeball it without mounting the wheel and having the suspension unloaded.
There are at least a couple of old race cars out there with altered wheel bases that moved the rear wheels further back in order to get more weight on the front end and reduce the oversteer problem. Watch this video. Jim Busby starts talking about 4:58 into the video.
https://www.youtube.com/watch?v=hfq7-1ePW-M |
This is the bumper, so this would have to move forward several inches too correct?http://forums.pelicanparts.com/uploa...1594842305.jpg
True , but the rear wheel on this are in ....
Is it all fibreglass ?
Take a pic of underneath showing your arms , and the mounting points .
What size tires are those? It looks like the tires are shorter than stock.
I would take some measurements from a stock car and see what is going on. I almost used FG fenders on my car..... |
It’s pretty easy for an “artistic amateur” to make fibreglass go wherever you want , so if said amateur put fenders on in wrong position they’d simply modify the bumper ends to suit . Pics of insides of a rear bumper end should show if it’s been cut’n’shut at all .. |
There was a car for sale on Bring A Trailer a while back with a similar problem , having used GT racing panels on my car i,m praying i don't have the same issue when I get everything assembled .
So where is the actual spring plate center relative to the torsion bar access hole in the flare?
This will tell you if the flare is relatively rearward compared to its supposed location. Looks like it also may be hung low. |
I’m thinking there might just be a mechanical problem and a bodywork problem , hence my request for more photos .
It’s easy to say the fenders are out , as the Torsion bar holes are nowhere near . But looking at an lwb dead on the side-view , edge of rear 1/4 windows lines up with side of Fuchs center-cap . It’s an angled photo so harder to see this and easier to get photos of rear arms as I asked , But swb -lwb arm difference is about 60mm ..... |
I just scrolled up and saw top photo :rolleyes:
It’s just badly fitted rear flairs , with bumper modded to suit the bad fit imho . Easy enough to fix . If not easily visible from underneath (they ussually are) Use a magnet To find where steel ends , and cut off and redo fibreglass . Most were done by laying over metal and riveting on , then glassing joint before grininding rivets and finishing . Though I’d preferably buy a new rear bumper first that was known to be a good fit , and work to that . |
| All times are GMT -8. The time now is 04:30 AM. |
