-   -   ENGINE GURUS! Help Me Compare A Stock SC Motor To.... (http://forums.pelicanparts.com/porsche-911-technical-forum/1067417-engine-gurus-help-me-compare-stock-sc-motor.html)
rennch 07-15-2020 03:20 PM
Doing a little research for an upcoming video.
I don't know engines REALLY well, so I'm curious how these specs differ from a stock SC 3.0 engine:
6 Cylinder, 2999cc boxer engine
4-valve, quad camshaft
aluminium cylinder heads
Open-deck aluminium cylinder block
Bore: 89.2mm
Stroke: 80mm
Rod Length: 131.5mm
10.7: Compression ratio
Dual timing chain system
Coil on plug-ignition system
Plastic intake manifold
Drive-by wire electronic throttle body
76mm OD3 exhaust-port cylinder head design
Variable lift and variable timing intake camshaft (ALVS and AVCS) much like Honda’s iVtec system.
Can you help me identify the differences, and/or point me towards a similar spec sheet for the 3.0 SC engine?
Thanks!
tirwin 07-15-2020 03:34 PM
I'll take my best shot. Others can add or correct if I got something wrong.
6 Cylinder, 2999cc boxer engine <-- SC is a 6-cylinder boxer 3.0L
4-valve, quad camshaft <-- SC is 2-valves per cylinder & 2 camshafts
aluminium cylinder heads <-- pretty sure this is true for the SC
Open-deck aluminium cylinder block <-- ???
Bore: 89.2mm <-- 3.54 in/90 mm
Stroke: 80mm <-- 2.77 in/70.4 mm
Rod Length: 131.5mm <-- ???
10.7: Compression ratio <-- I think US is 8.5:1? and Euro version is 9.3:1
Dual timing chain system <-- two chains
Coil on plug-ignition system.<-- SC uses captive discharge ignition, single coil and distributor to fire all cylinders
Plastic intake manifold <-- um, almost everything is these days?
Drive-by wire electronic throttle body <-- CIS fuel injection has throttle plate
76mm OD3 exhaust-port cylinder head design <-- ???
Variable lift and variable timing intake camshaft (ALVS and AVCS) much like Honda’s iVtec system. <-- no variable camshaft, cam profile is what it is
One of the main differences you didn't mention sounds like your other car uses EFI and the SC used CIS.
rennch 07-15-2020 03:44 PM
Literally Everything I needed. Thanks Tim.
Dual timing chain system <-- single chain
tirwin 07-15-2020 03:50 PM
Sure, no problem. Go back and look at my post again. I made a mistake and corrected it.
76FJ55 07-15-2020 03:55 PM
Open-deck aluminium cylinder block < Pretty sure this is describing the water jacket design on a water cooler engine.
Open Deck
https://dsportmag.com/wp-content/upl...1-OpenDeck.jpg
Closed Deck
https://dsportmag.com/wp-content/upl...ClosedDeck.jpg
dannobee 07-15-2020 03:56 PM
SC rod length is 127.8mm
SC CIS has aluminum intake tubes and a plastic plenum.
SC is air cooled, so the cylinders have fins, not open or closed deck as with liquid cooled engines.
Bigtoe32067 07-15-2020 03:58 PM
3.0 is 95mm bore
127mm rod length
The rest looks good
Tony
Arne2 07-15-2020 04:48 PM
6 cylinder, 2999cc boxer engine
open-deck aluminium cylinder block
bore: 89.2mm
stroke: 80mm
rod length: 131.5mm
dual timing chain system
coil on plug-ignition system
plastic intake manifold
drive-by wire electronic throttle body
76mm od3 exhaust-port cylinder head design
variable lift and variable timing intake camshaft (alvs and avcs) much like honda’s ivtec system.
subaru ez30-ii?
Flat6pac 07-15-2020 04:54 PM
What you list is not an SC 3.0, more like a more modern water cooled Boxter
Bruce
rennch 07-15-2020 05:20 PM
Originally Posted by Arne2 (Post 10947887)
subaru ez30-ii?
We haaaaaave a winnerrrrrrr
https://uploads.tapatalk-cdn.com/202...512e41f009.jpg
https://uploads.tapatalk-cdn.com/202...ee606aadf3.jpg
https://uploads.tapatalk-cdn.com/202...ca16395188.jpg
rennch 07-15-2020 05:21 PM
One thing I didn't ask, but it's worth knowing: SC engine 462lbs, Subaru EZ30 397 lbs.
jpnovak 07-15-2020 05:21 PM
And for EZ30 you have power output of:
180 kW
240 hp; 240 PS
@ 6,600 RPM[21][33]
297 N⋅m
219 lb⋅ft
@ 4,200 RPM[33][34]
If you boost it then typical limitations are about 340Hp.
https://www.possumbournemotorsport.com/ez30-info
Boosted 3.0 911SC could be above 500hp. Each requires money and skill to build for high power and address weak points and cooling.
I looked into this for my old Suby powered 914.
jpnovak 07-15-2020 05:22 PM
And then the weight is offset by the cooling system and coolant. But the distribution of weight can be favorable depending on locations and mounting points.
rennch 07-15-2020 05:34 PM
Specs say it takes a gallon of coolant, or 8 lbs. and about 5 less quarts of oil than a Porsche. So it’s a wash.
Mixed76 07-15-2020 06:10 PM
I think he was talking about the radiator and hoses. I don't suppose those weigh more than 20 or 30 lbs?
Looks like fun.
Sent from my Nokia 7.1 using Tapatalk
ian c2 07-15-2020 06:56 PM
I didn’t realize it was an advert , I thought it was a technical question
rennch 07-15-2020 07:25 PM
It is. What am I supposed to be selling?
rennch 07-15-2020 07:30 PM
Looks like fun.
Even then...a wash with an external oil cooler, which I have in my other car.
Either way, should be fun indeed!
Walt Fricke 07-15-2020 07:32 PM
Early SCs CR was 8.5:1. Later US 9.3, Euro 9.8.
4 valve water cooled engines with knock sensors and ECUs seem able to run a point or so higher on the same octane fuel.
There are nominally stock SCs out there which appear to put out 240 flywheel HP (estimated from RWHP figures, as not many shops have an engine dyno). How is a good question.
Hi_Fi_Guy 07-15-2020 08:57 PM
Kudos to you. Can’t wait to hear how this drives.
tirwin 07-15-2020 09:11 PM
What transaxle are you using?
ian c2 07-15-2020 09:15 PM
Transaxle ?
Isn’t that where Dracula comes from ??
Andy Somogyi 07-15-2020 11:35 PM
EZ is a freaking amazing engine. Saw one running stock cams, but AEM inifinity ECU, revving to 8000, and smooth as glass.
It looks perfect in there, has a real 928 look with that intake.
Are you using a Subigears reversed ring gear ?
Sent from my iPhone using Tapatalk Pro
blucille 07-16-2020 04:06 AM
Looks like a great fit, you’ve been busy. Nice work.
tirwin 07-16-2020 04:16 AM
Originally Posted by ian c2 (Post 10948166)
Transaxle ?
What do you call it?
rennch 07-16-2020 09:29 AM
G96 (996) cable shift 6 speed.
rennch 07-16-2020 09:30 AM
G96: cable shift, 6 speed.
rennch 07-16-2020 09:31 AM
It’s just sitting on a flat jack. I need to mock up an adapter plate as I’m still waiting on mine.
Rodney Nelson 07-16-2020 11:57 AM
Dang it! I shouldn't of read this post, now it is going to ruin the video! I'll pretend I didn't see this.
rennch 07-16-2020 10:24 PM
Ha ha! Sorry... #spoileralert
'78 SC 07-17-2020 04:07 AM
Referring to the notorious PCA E-stock, Walt? Mystery cams, perhaps?
