Shift Rod Ball Cup Question
I am in the process of replacing the shift rod bushings on my 68 911. Upon removing the shifter this morning I noticed a wire wrapped very tightly around the ball cup bolt. It is making it impossible to loosen and remove.
Please refer to the attached photos. Photography is not my strong suit, but hopefully you can see what I am talking about. You can also see the bushings are completely disintegrated and laying in the tunnel.
Has anyone else ever seen this wire wrapped around the ball cup retaining bolt? If so, what is it? I can't see it going off the shaft at all. Do I need to cut this to remove the bolt? I am starting to round the bolt due to the wire interfering with the wrench.
Any advice is appreciated.
Lou
Old 07-18-2020, 04:06 AM
Yes you need to cut the wire. Somebody wired it to prevent backing out of the bolt for some reason. Was your car ever a race car? Or double check that the bolt isn't stripped and that was a hack to keep it in place.
1973 911 S Ivory White, 5sp MT
2015 Macan S, Grey, 7 sp PDK
Old 07-18-2020, 06:11 AM
NorthernThrux,
Thanks for the response. I did get courageous and pried on the wire and noticed it went through a hole in the bolt. I cut it off and the bolt came out no issue.
The bolt is not stripped. The car was raced in local rallies by the previous owner back in the 70's, so interesting thought.
Thanks again.
Lou
Old 07-18-2020, 06:27 AM
The bolt is always safety wired to prevent it from backing out. Lots of times folks don’t replace it when refreshing the bushings. Easy to remove and replace.
Tony
1968 912 Softwindow Targa
1974 911 Lime Green Targa
2013 Cayenne GTS Meteor Grey
2003 Boxster S
Old 07-18-2020, 06:41 AM
