Seat belt/ brake light dash lights
I have an 82SC. My dash seat belt brake light combination lights don’t work. I replaced the seat belt relay and replaced the module in the dash. Still not working. Any idea what the problem? Need them working to pass inspection. Any way to bypass them?
Help please
Old 06-11-2021, 09:18 AM
Pedro '84 Coupe's Avatar
The bulbs are likely burned out. They are soldered into the assembly. That part is a bit of a pain to remove.
2000 Boxster S and 2016 Audi A6
Old 06-11-2021, 09:55 AM
proporsche's Avatar
Joe..just wonder where the heck you need that to pass the inspection.
If you said you replaced the dash unit is it this one?Also is your hand brake warning light working?
1985 911 with original 502 191 miles...808 198 km
Old 06-11-2021, 10:28 AM
I’m in Montreal Canada.
That’s not the one. Mine has the removable bulbs which is an earlier unit
Old 06-11-2021, 10:43 AM
proporsche's Avatar
ok let`s see it ..to insert picture go to advance and there is blue line ..use that
Ivan
Old 06-11-2021, 11:00 AM
Old 06-11-2021, 11:33 AM
proporsche's Avatar
same difference...just 2 light bulbs..again does the handbrake light works?
Ivan
Old 06-11-2021, 11:40 AM
proporsche's Avatar
is that the correct warning light unit..on the side you should the year
Ivan
Old 06-11-2021, 11:42 AM
No the hand brake light doesn’t work.
The date on the unit is 9.81. My car is an 82 build date Oct 81
Old 06-11-2021, 11:47 AM
proporsche's Avatar
have a look at the little contact switch on the base of your hand brake..there is an adjustment
Ivan
the lense says,seat belts and hand brake or what?
Fixing parking brake warning light switch
Old 06-11-2021, 11:53 AM
stevie 77 930's Avatar
These units can go bad and can be repaired. I sent mine to Tore Bergvill in Norway and he made a jig to test and repair. Came back working like a champ !
https://www.bergvillfx.com/categories/control-units
Here is mine.....
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 06-11-2021, 12:00 PM
I replaced the module with another one
Old 06-11-2021, 12:07 PM
does the seatbelt light go on when you turn on the key ?
1983 911SC
2018 GTS
2023 Audi A4
Old 06-11-2021, 12:10 PM
When I test the switch at the hand brake handle with a test light the
switch works
Old 06-11-2021, 12:12 PM
It did originally
Old 06-11-2021, 12:24 PM
Is there a work around to bypass?
Old 06-11-2021, 12:38 PM
Enginerd
TxGerman's Avatar
I have a slightly different issue. My parking brake light works but I have never seen my seatbelt light come on. Could be the bulb, but could also be the switch. Is there a way to inspect/replace/adjust the switch in the seatbelt receiver? I have not gone into this rabbit hole yet, but this thread is the first time I've seen a discussion about these bits.
Dennis
1982 Guards Red 911SC, 1994 Riviera Blue RoW 993, 2020 British Racing Green Macan GTS
Gone but not forgotten: 2017 GT Silver Turbo S, 2012 Guards Red 991.1 C2S, 2017 Carrera White Macan GTS
IG: @pcar911fan
Old 06-11-2021, 01:04 PM
My car is an 82 guard red targa
Old 06-11-2021, 02:19 PM
Dennis
The first thing and easiest thing to check is the bulb. Pry the lense off carefully and replace the blub that is failing. You made need a small pair of needle nose plyers to pull the old blub out.
1983 911SC
2018 GTS
2023 Audi A4
Old 06-11-2021, 02:57 PM
I have replaced the bulbs
Old 06-11-2021, 03:05 PM
