Door release removal help
I am knee-deep in trying to repair my driver's door for a few things and I need some help.
First: how do I remove the pin holding the door release? I have removed the circlips and would assume the pin would then fall out. I have used some penatrent but I feels like it's welded in.
Second: I originally removed the panel to try and fix the lock actuator. The driver's door won't unlock with the key but not lock with a key. The central locking system works from inside both the button and the manual knob so I don't think it's the actuator solenoid.
Any ideas and help is much appreciated
Old 06-12-2021, 06:11 PM
Inside door handle pin pic. It's a little rusty so I did hit it with penetrant.
Old 06-12-2021, 06:18 PM
Got it! I used the Dremel to get it as clean as I could and rigged up a lever system consisting of two screwdrivers, channel locks, and a vice to lever the pin out.
Polished pin
Completed handle
Old 06-12-2021, 08:13 PM
Is that ar15 diagram mat on your workbench?
Old 06-13-2021, 07:21 AM
Good eye. It's a 1911
Old 06-13-2021, 10:06 AM
