MSD Fuse?
Hello Pelican brain trust!
I have a MSD 6 AL digital that I believe has failed. When going thru this I noticed the leads for the MSD are going direct to the battery but are not fused. Should they be and which one the positive or negative? What size fuse? Thank you!!!! Mike |
https://www.holley.com/products/ignition/ignition_boxes/street/parts/6425
Instructions at bottom of text |
Thank you Ian
You’re welcome , I’m glad I could help .
There’s a test procedure in there too . |
| All times are GMT -8. The time now is 10:46 PM. |
