Any Experience With Chinese Made Empi LugNuts? Pics
Guys / Gals - I recently bought a brand new set of Porsche aluminum lugnuts made by Empi. Once I received them and really inspected them they seem to be well made, and maybe or maybe not surprised they are made in China. Either way not wanting to play Russian Roulette with a wheel flying off!
Curious if anyone has experience with these? And next to them are my 33-year old OEM Porsche ones. Thoughts? Thanks, ![]()
Ole Skool - wouldn't have it any other way |
I'm good with tools.
You lost me at Chinese made.......
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
I'm not sure it's a good idea to chrome the shoulder that touches the alloy wheel.
Mark
1979 911SC Targa |
Coram Deo
I'm sure it's not a good idea to chrome the shoulder that touches the alloy wheel.
Fixed it for ya.
Dru 1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter • 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio • |
a.k.a. G-man
agree with all three above
Сидеть, ложь, Переворачиваться |
The key thing to know is the metallurgy of the lug nut material. True OEM Porsche (like your originals) was a special alloy; very strong/light, and durable. With that funky plating on there it is hard to tell...
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter Last edited by Lyle O; 07-17-2020 at 06:44 AM.. |
cycling has-been
Very low probability of your wheel 'flying off' is if, a) all 5 lug nuts are engaged and b) all are torqued properly.
If the new lugs start to fail individually, I'd start looking for new set.
73 911T MFI, 76 912E, 77 Turbo Carrera |
While it’s impossible to avoid Chinese products all together I avoid them whenever possible for two reasons. 1. They want to destroy us 2. Cheap Junk.
It is very unlikely that the lugnuts will fail and a wheel would fly off. A more likely failure scenario is that the threads are poor and after a few repetitions one of them will destroy a wheel stud. I doubt you will have that or any other problem though.
1972 911T targa |
The machining and finish quality certainly lives up to them being made in China.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Why is that bad ?
1986 Bosch Icon Wipers coupe. |
Thanks guys.
I bought these unaware that they would actually be made in China. I figured a well known brand like EMPI that has been around for decades would be quality products...so was shocked as you all when I saw the country of manufacture. I guess its no different that the high percentage of products being made in Mexico as well. Curious like sugarwood, why is it bad with the chrome shoulder touching the alloy wheel?
I think maybe the chrome layer would deteriorate and will cause the nut to loose out.
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management. -1987 Carrera Coupe. -2013 Carrera S PDK Coupe, factory Aero Kit. My DD. -1987 928S4. |
Caveman Hammer Mechanic
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
The surface finish of the hex faces isn't very good and the nickel base plating is pitted, giving the chrome on the seat radius that pock marked effect. Neither should affect it's ability to hold the wheel on, but the plating will likely peel faster than a lug that was coated correctly.
And just like here in the states, you get what you pay for. There are tremendously talented machine shops in both countries, and also some real hacks. In this instance, do you want the surface finish to be smooth and the plating to meet ASTM standards for visual appearance and adhesion? Just add those requirements to the drawing and watch the quotes double in price. Cheap - fast - good; you can only pick two at a time.
-Tony Instagram: @Pablo_the_Porsche | @RuchlosRallye AchtungKraft #002 |
Rennch on YouTube
empi has been around for a looooooong time, so unless those are a knockoff, they are probably just fine.
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
AutoBahned
1. not NOT NOT a good place to save $$
2.try one on each wheel with the real lug nuts - see what happens |
An aluminum nut will never destroy a steel stud.
If they are junk the nut threads will strip when torquing. Otherwise they will hold just fine. And I have used plenty of chromed steel lugs and never had one come loose. Use them Sent from my iPhone using Tapatalk
Derrick |
Under the radar
The problem is the fact that chrome plating aluminum is not chemically stable. There is a potential for galvanic corrosion which will cause the chrome to peel. If you keep the lugs dry AND they did the plating correctly you should be OK.
You might want to recheck the torque once in a while.
Car parts are made to a price point. China doesn't automatically mean junk. Those Empi nuts are like $7 each. They are not cheap at all. They are likely very high quality. He is totally fine, and it's silly to see the hysteria on this thread.
