Door / speaker hardwear parts needed
Hardware for speaker mounting shown, threaded stems that are anchored inside the door panel that holds the speaker in place
Are these parts available anywhere? ![]() ![]() ![]() ![]() Last edited by jgurnari; 07-22-2022 at 01:04 PM.. Reason: spelling |
Try grainger or McMaster Carr they’re called Mountable Threaded Studs.
If all else fails, there’s a 3/4” elevator bolt which is the smallest length, which has a flush head.
Maybe those old ones can be reattached (cleaned, painted, prongs straightened and sharpened) if replacing the door card with new stock, but they look delicate and may not withstand a strike with a mallet, or some JB Weld? Another suggestion would be a fabrication, using a small speed nut with appropriate sized stud JB a welded in place. |
Banned
I appreciate the information and advice you have shared.
My Mercy Last edited by Callum69; 07-25-2022 at 08:30 PM.. |
Thats quite a bit of rust. Do you have the plastic sheet vapor seal in place on the door behind the door panel.Keeps the water off the door panel and a flap should cover the back of the speaker
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Tags |
speaker insert , speaker mounting |
