915 Shifter Couplers
Any suggestions on which shifter coupler (WEVO or Stomski) will best improve the shifting of my 85 911 with a 915 5 speed transmission ?
Also, should I also replace the Motor and Transmission Mounts? Thanks again for any advice, Ken |
I put the Wevo in my '84...BUTTER! So easy and a great upgrade!
1984 Carrera Targa, Moss Green - Sold (biggest mistake) 2008 Carrera 4s, Macadamia (Brown) |
Banned
Stomski copied Wevo's design, which is really nothing more than a sized coupling joint used in many industrial applications
a search will be rewarding... |
The stock coupler with black delrin round hole bushings installed, work just as nice as the fancy ones.
john walker is my man
1984 911 Carrera Coupe - 32C #73 - M64/05 1998 E36 M3 4dr 1989 E30 325i 4dr 2006 Sienna 5dr - the hauler 2010 Cannondale Caffeine II - Lefty |
In the early days of my SC ownership I replaced the engine and transmission mounts - an easy job, and it hugely improved the gear shifting. I think the engine and transmission were moving a bit while under acceleration, then moved again as I put the clutch in to shift gear.
I used what were called Sport mounts. Slightly stiffer rubber I suspect.
see www.lyallbaybeach.co.nz |
If in doubt of wear-grade in parts influencing proper shifting, here's a to-do:
- replace lower ball joint bushing of shifter - replace coupler bushings - replace trans mounts (maybe engine mounts in the go as well) - reajust, drive off like 1985 new from factory the easy way to go one step further: - get the spring from Karsten => THIS - improve coupler to brass bushings or the WEVO PJS coupler
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Parts: https://www.instagram.com/spadescustomz_/ EGO: https://www.instagram.com/911garage_germany/ |
I put the wevo in and it shifts beautifully now (had a recently redone standard coupler inbefore). Next : transmission mounts
I don’t believe there is much difference between the wevo and the stomski. Sent from my iPad using Tapatalk
__________________ 1985 Carrera 3.2 |
I have the Wevo Shift coupler and the Wevo engine/tranny mounts. Could not be more pleased with the feel and handling of a almost 37 year old 911. 😊
Bruce '12 Carrera S DFI '84 911 Carrera |
Thanks for your replies.... Always appreciate the advice from this group.
WEVO Coupler, new shifter bushing, engine and transmission mount are in the plans. Any suggestions on Mounts. |
Still here
Good to know the stock coupler with this 10$ part will do the same while keeping the dampening rubber bushing in place. Adding it to the todo list the next time I have to adjust the linkage.
Thanks John, they are now on my shopping list.
Banned
There are 4 levels of 'stiffness' for engine/tranny mounts. In addition, you can mix & match by puttng stiffer ones at the trans vs. engine
Blue Wevo - stiffest Black Wevo Cabriolet Stock, non-cab mounts - least stiff Avoid solid mounts. Replace the stock mounts if a PO did not - as they are old and hard, brittle. |
I did the brass coupler insert, replaces the factory plastic piece. Seems to work great
72 914-6 GT Conversion 2.7 82 911 SC Coupe 78 SC Targa Hotrod |
Brew Master
FWIW, I've driven a car with a wevo coupler and the owner of that car drove mine. We both agreed that there was no difference in the feel of the shifts between the two.
Nick |
I used the Stomski and am very happy with it.
The only thing I noticed is a bit of noise in gear at the shifter- sort of a buzzing kind of noise- might need a little adjustment so the lever isn’t tight against the housing, but haven’t investigated yet.
Rutager West 1977 911S Targa Chocolate Brown |
When I removed my original coupler, I was astonished how degraded the original bushing was. Replaced with a Wevo. Big improvement, but bailing wire might have been an improvement too.
However, it transmits a lot of transmission sounds into the cab. Clearly, need to finally get that trans overhaul and upgrade. The original bushing provides an intentional oval movement, while the Wevo is very precise bearing movement. I've rebuilt my original coupler with the delrin bushing and want to compare the two (Wevo vs. delrin) once I put the trans back in. |
Also used the Stomski coupler along with JWest's Rennshift and very happy with the combo.
Rescuer of old cars
When I bought my '84, the PO had installed a factory short-shift, the transmission had fresh synchros and sliders but shift quality was poor. I replaced the linkage bushings, upgraded the transmission mounts to the firmer sport/cabrio parts, removed the short-shift kit, added a Seine Gate shift kit and delrin bushings in the stock coupler. Car shifted great after that was done. My new '72 (also with fresh 915) isn't too bad, but I am still planning on delrin coupler bushings and the firmer transmission mounts. I can't see that either the Wevo or Stromski couplers could be much better than the delrin bushings.
"Honestly now, did you spend your youth dreaming of someday owning a Nissan or Mitsubishi?" - Porsche ad from early '90s 1972 911T coupe Priors - '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Bragging rights is all.
Thread Tools | |
Rate This Thread | |
