kuba_kuba's Avatar
Windows stuck mirrors also inop - suggestions
Hi Folks,
The other day my after starting the car, went to lower the windows and nothing happened. Neither window moves with the switches on drivers side and neither does passenger window using passenger side switch. The mirrors are also inoperative on both sides.
I may have opened the drivers door "all the way" to the end of the door check (which I never do) with a bit of force as car was parked downhill.
Didn't have time to dive in too deep yet but fuses appear OK.
What would you do next? I'm thinking:
1) double check fuses
2) check connectors at door switches for both windows and mirror (have to take some of the door apart for that)
3) check wiring to the door? how do you get at it? Area behind door hinge when door open seems unreachable
4) check window relay behind dash?
Open to any suggestions/tips. Getting windows working is more urgent than mirrors. Car is a '88 targa
Please and thank you!
'88 911 Targa
Old 07-24-2020, 09:15 AM
You can pull the window switches and check their connectors without removing the door card. But, does the window switch work on the other door?
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 07-24-2020, 09:20 AM
kuba_kuba's Avatar
No - switches do not work on both doors. Both worked fine until now.
'88 911 Targa
Old 07-24-2020, 09:31 AM
lake wales fla
I would look closely at the fuse and if you have power at both end's then Check the relay behind the Fuel/oil level guage
Richard
Old 07-25-2020, 05:28 AM
kuba_kuba's Avatar
Some progress: #1 Fuse was blown. New fuses blow when window switch is pressed "Down" - I I guess I'm looking at a short in the motor or wiring leading to it?
Sorry for the naive questions - I'm a mechanical engineer who has tried very hard to have as little to do with electricity as possible...
'88 911 Targa
Old 07-25-2020, 09:19 AM
I'm good with tools.
AG81's Avatar
Short in wiring that passes thru the door from body ??? Just asking because I had an issue on the passenger side during my build.
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 07-25-2020, 09:48 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Window.
Another possibility is that the door harness
has been pinched inside the window mechanism.
pm me as needed.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-25-2020, 11:08 AM
kuba_kuba's Avatar
Follow up:
1) Mirror issue was my own stupidity - forgot to plug harness back in when reassembling door a few months ago. Guess I never needed to adjust mirrors in the meantime.
2) Window issue was a short in the regulator motor. Got the motor off thanks to this awesome thread Targa Window Motor Replacement then cleaned up motor, tested and re-installed. All good.
Thanks for the help.
'88 911 Targa
Old 07-26-2020, 06:51 AM
Thanks for the update! Good to know it's fixed.
1990 964 Coupe
Old 07-26-2020, 07:53 AM
