Signal LED
so I removed my front bumper and discovered why people hate the turn signal wiring so much. Have some connectors on order to splice them in but anyway. When I opened up my turn signal housing I noticed the entire setup with the bulb is garbage and also brittle. Instead of buying an entirely new housing I was thinking of getting the LED turn signal panel from Spokeworks. I noticed it’s set up to connect directly to the bulb housing but I was wondering if anyone had just removed the reflector altogether and just wired it directly in? Seems a much simpler way to do it.
Old 07-31-2020, 07:51 AM
This is what I’m going to eventually do. Hate those bulb housings!
Old 07-31-2020, 08:09 AM
Uncertifiable!!!
Uwon's Avatar
[QUOTE=richardoux;10968382................I was wondering if anyone had just removed the reflector altogether and just wired it directly in? Seems a much simpler way to do it.[/QUOTE]
You are going to introduce another source for moisture........
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 08-01-2020, 04:25 AM
