HELP needed. 73/74 Sunroof experts out there?
HELP needed. 73/74 Any 911 Sunroof experts out there? PM me PLEASE.
Turbo, there is a recent thread discussing how to remove, adjust and service your sunroof. I suggest a quick search? It was very helpful to me.
I suspect few differences with the exception of the air deflector. Best of luck
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe |
Thanks, but I need someone that knows the difference between the 73.74 motors and mounting. I have a 74 Carrera with 73 motor and mounting. I need to understand a why I can use the 74 motor. It just doesn't fit. Or If I can send my motor out to get rebuild etc. Its slow and weak, especially right when the sunroof ends closes and then pops up.
Suggest you simply help it by pushing up and forward as the roof is closing. The cables do tend to break and lubrication is needed. Also there is a hose that connects the motor to the transmission that wears out also.
Chris 73 911 E |
New cables, motor tested and the piece between is what is considered the clutch.
Post a picture of the motor
Photos
Here is a picture of what I thought was an early one with the later one next to it on the right. But neither of them are made for a side mount like yours. Not sure. As pointed out above, there are a lot of issues before you get to the motor can be causing your problems
this one has a side bracket. And it operates with a 5amp fuse.
From 73
This is from 73 and my Carrera is 74. I think I need a new motor and trans even though the both work. IDK
ahead of the curve
I have one just like yours that wasn't working when I got the car (73) . I found two problems:
1. one of the crimps to the motor wire failed and was not electrically making the connection anymore. 2. the grease in the cable tubes had congealed making it overly difficult to drive the cables.
19 Carrera T - MPS member 92 C2 SR coupe M491/ 3.8 look- manual 92 C2 SR coupe cobolt blue- manual 73 914 1.7 (?) AG -a solid project looking 4 a sugar daddy 73.5 T gemini blue SR coupe sold 8/22 my last long hood gone
2. Tubes are all cleaned out and new cables installed. Frustrated. lol |
ahead of the curve
the crimp is a mechanical connection where metal is bent with a plier like tool to make an electrical connection between a wire and a wire or wire and a connector. The crimp I was talking about is where the wires that comes out of the sunroof motor are attached to the wires from the car. If your sunroof motor is working it sounds like that isn't your problem.
did you de- fuzz the cables and do they slide through the tubes without a lot of resistance?
Registered Minimalist
Agree with Jeff, The crimp point is a weakpoint in the design - I had the same issue with my 75 motor. You could literally reach up while holding the open button (what can I say I have long arms) while jiggling the wire into the motor and it would work sporadically.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Defuzz. Hmmm. Defuzzing now.
ahead of the curve
ok, making progress ! exercise it giving it some manual help (don't overdue it and overheat the motor). still not shutting on its own? - disassemble and thoroughly clean all sliding parts. if you have done that already try a dry lube. If you have eliminated all the resistance it might just be the older motor/trans doesn't have the power to do the job anymore.
Recently a Porsche acquaintance told me he has modified later sunroof motor/ trans to work. If you finally give up on the original motor and trans, I can provide you with his name and contact info if you pm me.
