-   -   MPI Steering Wheel Hub Adapter (http://forums.pelicanparts.com/porsche-911-technical-forum/1068722-mpi-steering-wheel-hub-adapter.html)
88_Targa 07-29-2020 08:45 AM
Hi, I have an 88 Targa and have been contemplating for a while changing out the stock steering wheel for a MOMO type wheel. However, I recently discovered the new MPI Autodromo 70/80 wheels that look great and are a little wider diameter (360mm vs 350mm) than the momo prototipo that I think would work better. I was planning to just use the standard momo hub adapter to install, but just noticed that Pelican Parts carries an MPI Porsche hub adapter. It looks very similar to momo type but have never heard anyone using it and can't find any reviews about it anywhere. Does anyone have any experience with this adapter? Seems to make sense if I install an MPI wheel, to also use an MPI hub adapter unless there's a major issue with it.
On a similar note, anyone else using an MPI Autodromo steering wheel (either the 70 or 80 version) and would you recommend it?
Thanks so much!
88_Targa 10-28-2020 06:58 AM
FYI, I took the plunge and just installed a MPI Autodromo 80 with the MPI hub adapter. Everything went perfect and the quality of the MPI products are fantastic and I couldn't be happier. I hope this helps others who are unfamiliar with MPI and may want to consider something other than Momo.
