| Arne2 |
08-03-2020 11:58 AM |
Originally Posted by archstanton
(Post 10971627)
Arne2 my experience with the SS in my '86 is the same as yours. I would expect more effort needed w/ the SS, but smoother shifts & easier adjustment with the non-SS surprises me. I guess you expected to see those improvements when you did the switch. Why was that?
I expected the improvement in coupler adjusting, the smoother shifting was an unexpected side benefit.
The issue I had was that the reduced travel meant that the shift lever was not moving far enough forward on shifting to 5th to let the lockout cam swing into position. Adjusting it so that the cam would clear the lever didn't allow full travel into 2nd and 4th. So a slightly longer travel lever was needed.
